Question about Samsung PPM-42S3 TV Speakers
I have a samsung display tv, and I want to add audio, how do I bring sound external?
  • 616 Answers
I suppose we should guess the model number?
Posted on Jul 19, 2010
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
I have a Samsung UN46F6300 TV and the external sound output has quit working. Would replacing the T-com board most likely fix this problem?
Check the audio settings menu of the TV. May be there would be an option to select the audio output whether you wish use inside speakers or external amplifier. if its there then You have to change the setting to external amp.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 26, 2016 | Samsung Televison & Video
No sound on lcd tv
First check your TV setup menu to see if your TV audio preferences are set to PC audio. That is a setting that sends audio out through your PC cables instead of the TV speakers. It may also have been set to mute through a remote.
May 02, 2016 | Samsung LN40D630M3F
How to connect my bose solo to my 2009 samsung tv
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Oct 12, 2017 | Samsung LN46D630 46 inch LCD 630 Series TV
No sound from the audio speakers
by audio speakers i assume you mean speakers that you plug INTO the tv, some tv's if you plug in speakers they play instantly but some tv's you might have to go under the menu ON the tv so just bring up menu, click on audio, and it should say some where to swith to external speakers then while with speakers pluged in select external speaker (or whatever your tv might say) and i hope that solves your problem, thank you, jamie.
Dec 15, 2012 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
I got a samsung le32 tv i got sound but no picture can you help please
Connect your TV to a DVD player. If there is still no picture, it means the display inverter of your TV is defective.
The display inverter is what makes the TV brings picture. Since the TV is no longer bringing any picture, the display inverter is the first thing that needs to be checked as it is most likely the cause of the problem.
Please give me feedback if you need any assistance in locating or identifying the display inverter.
Your sincerely.
Elect_Comp.
May 16, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
May 16, 2010 | LG 32LB9D TV
How do you use external speakers when you have no sound on the tv
Bring up the TV menu on screen by pushing the menu button on the remote that came with the TV, access the audio menu or you may have to select the set up menu(different TVs have different menu systems) but what you want to look for is make sure the TV speakers are turned "ON" TVs of today give you the option to have the TV speakers "ON" or "OFF". If all is well there, in order to connect external speakers to your TV you would have to send the audio signal out of the TV to an audio receiver/amp by way of RCA style patch cords. TVs these days do not have an internal amp that is capable of powering external speakers, that is why you do not see speaker wire terminals on the back of your TV. Good luck !
Jan 06, 2010 | Polaroid FLM-323B Television
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Samsung PPM-42S3 TV Speakers Logo
102 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
