Can anyone give me an installationset out for for a brivis M30e Gas central heating system ie the size ducting needed for return air vents outgoing vents and sizes before you can drop down is size. I have had a go at installing it but I think my ducting size my be all wrong
    President:
  • 1,070 Answers
Welcome to Fixya
Sir
I hope Following Link can help you
Complete the form to get a free appraisal for installing a Brivis system.
Check this Link
This Link
Product Documentation here
Thanks for Contacting FixYa
Posted on Jul 16, 2010
What size central a/c,heater do I need to cool-heat a 2400 sq/ft house in west Texas
You haven't included enough information to give you an accurate number. Things to consider are:
- R value of attic and wall insulation
-cubic footage of the living area
-are the windows single double or triple paned... low E ?
-how many hours of direct sun?
-how many points of return air do you have?
Its better to over size your system than to undersize.
One more thing to consider.... heat rises, cooled air falls and if you want to run your ducting under the house? insulate the crawlspace walls.
Nov 19, 2013 | Heating & Cooling
I just installed a new 410 -a central air system.its a 2 1/2 ton unit woth1200 cfm blower. Filter is clean. Supper heat is fine.but unit is not cooling below 62degrees air. And not very much condensate...
I would look for torn flex duct if the ducts run beneath the building (cats often tear
holes in them and it will cause this condition). Or separated ductwork somewhere
near the return vent. Hope this helps.
Jun 09, 2011 | Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
I need to know what size central heat and air unit i need for my house
Absolutely, can you give me the following info?
Do you have ducting? If so how many vents? How many return vents, and what size? How many square feet do you have to heat and cool? Are you replacing an old unit? If so whats the old units model number and make? Are you buying the Heat Pump, gas furnace, electric furnace, or dual fuel, or Air conditioner?
Thanks a lot of questions, but extremely important in sizing your home.
Dec 08, 2008 | Heating & Cooling
My hvac duct work on one of my central air units has a lot of condensation and causing puddles of water throughout my basement. Do you know what the problem is? The drain lines don't seem to have any...
could be just not insulated enough is this a new instalation? the humidity is too high around the ducts is their a return air vant close by that you can open? you need to lower the humidity or seal the ducts so it cant get to them dan
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
