Air conditioner and dehumidifier on at the same time, all the time. Constantly having to empty water. Is there a way to just run the AC without the dehumidify function? Manual is no help.
  • ccletta Jul 18, 2010
    Oops, sorry.
    Hisense 3 in 1 portable air conditioner dehumidifier.
  • 57 Answers
Without knowing the make and model no., can't help you....
Posted on Jul 16, 2010
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Tip
    Dehumidifier VS. Air conditioner
    A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
    How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
    1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
    2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
    3. The dehumidifier reheats the air and exhausts it back into the room.
    A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
    on May 18, 2010 | Dehumidifiers
    Carrier holiday elite 12
    I believe this means you need to empty the water catch tray. Normally a pull out tray at the rear with a float arm in it. It will keep happening as the water is condensed out of the air during the dehumidification. Empty it out and start again, it will need regularly emptying.
    Jun 02, 2013 | Heating & Cooling
    Not condensating the water out the exaust hose.. having to drain every few hours
    Since your model also has a Dehumidifier feature, make sure that is turned OFF. Running that and the AC mode at the same time will generate more water than usual. Plus, it puts a strain on the AC side, as it will only operate at half capacity, if the dehumidifier is operating at the same time.
    Also, make sure that the exhaust hose is not clogged or has a significant downward bow to it.
    Hope this helps you and thanks for choosing FixYa.
    Aug 02, 2011 | Sharp CV10NH Air Conditioner
    I bought one of your products last year and for some reason most of the time i run my air conditioner it gets really humide in my room even my clothes and my bed feels wet. Anyways ino theres a...
    Without knowing what brand AC you have and the correct Model Number, there's not any way, we at FixYa can help you. By the way, you didn't purchase your unit from us, as we don't sell any appliances, whatsoever. But, we can help you troubleshoot and hopefully, solve the problem.If we have the above information.
    Please advise .. Thanks.
    Jul 05, 2011 | Danby Heating & Cooling
    AC is New Air model ACP 1000 E The unit fills up every 5 hours. Is there a way to run the AC without the dehumidifier? The setting is currently on the snowflake.
    No, a byproduct of cooling the air is condensation....or dehumidification... so in short.. if you want to cool the air you will also dehumidify it...
    heatman101
    Jun 15, 2011 | NewAir ACP-1000E Portable Air Conditioner
    I have a Martin Industries model DH50 dehumidifier that runs constantly until full of water. I can't shut the unit off without unplugging it and I can't control how dry I want the area. What part...
    Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
    May 17, 2011 | Heating & Cooling
    I have a Matrix dehumidifier which says it`s a Refridgerant,does it means it`s like an airconditioner?If so how do you use it nothing on the manual to illustrate & do you fill it with water...
    Dehumidifiers are small Air Conditioners that blow their cool air over the condensing coil rather than into the room. They work exactly like an AC unit except they don't blow their warm air outside. If you can install an AC unit of about the same size, you can dehumidify AND cool for the same energy costs. All you should need to do is plug it in and run a hose to a drain or keep its condensate tank emptied. By the way, the water it produces is free of minerals and some people say its good to wash your hair with. (?)
    Apr 01, 2011 | Heating & Cooling
    Air conditioners remove the moisture from the air, and so does a dehumidifier. Does running a dehumidifier make the air conditioner run less? Does running the small dehumidifier save energy in that the...
    a dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, but you are correct, when you run an air conditioner it acts like a dehumidifier and dries the air. as far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air use a dehumidifier if you want cool dry air run the AC but not both.
    How can I determine if the ac is removing the correct amount of moisture from the air?
    tech answer is:3 pints of water per hour per 1 ton of cooling.
    General rule of thumb is 20-25% of the capacity of the unit is devoted to dehumidifying.
    If unit runs constantly and the temp really does not seem to be effected, unit is probably too small. If unit runs and cycles off frequently, i.e. short run times, and humidity is high, unit is too big.
    Hope this helps
    Jun 25, 2009 | Heating & Cooling
    Heating & Cooling Logo
    104 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Marvin
    Marvin
    john h
