Question about Kitchen Appliances - Others
Wiring in a remote motion sensor to existing lights
I have a pair of lights on my detached garage, the driveway swings in from the side street and is between the house and garage. The lights are controlled by two switches, one in the house and one in the garage. My question, would it be possible to wire in a remote motion sensor somewhere say on the corner of the garage so at night, the garage lights would come on if A) a car pulled into the drive, or B) someone walked through between house and garage? I'm not sure it can be done and if so, can it be done only for after dark, maybe in conjunction with a dusk to dawn switch???????
    Top Expert:
  • Kitchen Appl... Master
  • 53,736 Answers
Yes it can be done and they are on the market from regular hardware retailers and security specialists
they come as a complete diy box with the light/movement sensor and a light fitting
the sensor "sees" daylight and turns off the unit until the lux reading drops then turns on the light
on off is controlled by the setting that you make on installation
motion then turns on the light and the period that the light remains on can be set by the knob adjustments
Average cost starts around $25.00 aud up to $100.00 aud depending on quality
normally they have only 1 light of 100 watts included in the box but they will run successfully on 15 watt fluro bulbs because all that is wanted is light and a 15 watt fluro bulb puts as many lumens ( light measurement) as a 100 watt bulb
if you want to run more bulbs of higher wattage , talk with an electrician about putting a relay after the sensor so that the current flow through the sensor is reduced and allow it to operate better and longer
Posted on Apr 21, 2017
Blue Dog
  • 75 Answers
SOURCE: Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: Dual Brite sensor lighting. Lights will not stay
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Posted on Jul 17, 2009
thunderalley
  • 432 Answers
SOURCE: i have had a motion floodlight installed about a
there will be settings on the base.they are small
Posted on Sep 24, 2009
  • 43 Answers
SOURCE: Bulb comes on, turns off immediately on timer-installed switch
there could be a few reasons for this,
1. the timer could have been damaged during a power surge, = unusable and needs replacement
2. The program set to switch on and off was lost, and needs to be reset, try to operate the reset button, and setting the parameters again., If this is the cace, make sure the backup battery is still ok
Posted on Oct 24, 2009
  • 864 Answers
SOURCE: I just bought a house with the Night Sentry EJ351
Here are the instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
You will have to pick the times you want the lights to go on and off.
Posted on Oct 29, 2009
I have a Defiant 180 motion security light that no longer stays on continuous but only blinks when activated.
Your motion sensor lights are supposed to give you a sense of security and peace of mind.
Instead, they're driving you crazy because they won't stop turning on and off, regardless of whether there's an actual intruder setting them off or not.
If your motion sensor lights keep flashing on and off, you should try:
  • Checking whether they're actually flashing on and off or just flickering
  • Adjusting the motion sensor positioning and settings
  • Adding "side blinders" to your sensor
Let's take a closer look at some of the ways you can stop false alarms from your motion detector lights.
If you're not up for any DIY troubleshooting,install the 6ya.com app we will be more then happy to help!!
First off, are they flashing on and off or just "flickering"? If the problem is that your motion sensor lights are flickering, you have a completely different problem than the one we're are talking about in this how to.
Flickering lights (lights that produce unsteady, rapid changes in brightness) are usually caused by one of 3 things:
  • A bad bulb
  • Bad connection between the bulb and the light fixture
  • Problems within the circuit
install the 6ya.com app we will be more then happy to help!! for more help on this problem.
So if you have a motion sensor light that flickers when it's on, we suggest you first try changing out the bulb. If this doesn't fix the problem you'll want to have an electrician check the circuit for bigger problems.
However, if the problem is that your motion sensor lights are false-triggering, continue reading below for some troubleshooting tips.
Adjust the sensor settings Most motion sensor lights have an easily adjustable sensor. This sensor "trips" when it senses a significant change in the level of heat within its vision (that is, an intruder moving within its view).
Now, if the sensor is positioned poorly or if the settings aren't set correctly, it may pick up heat from areas it shouldn't (for example, movement from branches, cars in street, etc.). Use the steps below to make sure your motion lights are positioned and set according to your needs.
Step 1. Move the sensor from "Operational" to "Test" mode. This switch is located on the bottom of the sensor and turns the light off after a few seconds, allowing you to test different settings quickly.
step 2. Make sure that the sensor is directly facing the area you want it to "guard." If you want it to pick up on movement within the driveway, make sure it's tilted down far enough to prevent catching movement from the street but high enough so that it isn't going off when the breeze stirs the flowers lining the driveway.
step 3. You can also check the bottom of your sensor for a "range" dial. This switch dictates the distance that your sensor will detect heat/movement. If it's set to "max", lower the range.
step 4. Adjust any animal immunity sensors. Some motion detectors allow you to choose a pets or animal immunity setting so that the detectors won't trip when pets or animals up to a certain weight pass by. First off, make sure that yours is on if you have pets or animals . Secondly, most pet or animal immunity settings allow you to choose a weight setting. Make sure yours is set to the weight that matches the animals likely to pass by the sensor's field of vision.
5. Reset your sensor to "Operational" mode when done.
If you've played with all of these settings but find that your motion lights are still going off when they shouldn't be, continue on to our next tip.
Try "side blinders" Every motion detector light sensor has a particular angle range. Most angle ranges are anywhere from 180 degrees to 360 degrees.
But sometimes, a sensor's angle range is too wide and is triggered by unnecessary movement, like tree branches swaying.
Try putting thin pieces of electrical tape on one or both sides of your sensors to narrow its field of vision. This can be a "trial and error" process as you experiment with various thickness of tape so be sure to put your sensor in "Test" mode first.
I Hope This Help's We Are Here To Help you!!
Nov 29, 2017 | Home Security
Only the multi function control panel opens/closes garage door. Remotes and keyless entry do not work.
There's a lot of things that can cause range issues. Wireless routers to close to the garage. Bad LED or CFL bulbs. Faulty circuit board. A faulty motion detector on a light. Sometimes if you turn all of the breakers off except to the garage you can isolate it. If that doesn't help call a garage door company to come out.
Jan 13, 2016 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
My Liftmaster remoter sensors do not light up any longer. No work has been done that would have bothered the wiring from floor to ceiling. I installed a new pair of sensors and they did not light up as...
You need to eliminate the possibility of a broken or shorted wire to the sensors even though no work has been done. It is possible a staple could have worn through the insulation due to vibration. It could be the opener itself but that is the last resort.
Aug 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I disconnect the motion detector on the Chamberlain 3/4 HPS Whisper Drive Plus Belt Drive Garage Door Opener with EverCharge
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Jul 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Door will not open or close with remote
What does a normal remote do with the lights?
Is yellow and green normal?
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 971LM opens but won't close correctly
Check the wiring going to the sensors to make sure it is not broken or disconnected. You have a problem with the sensors themselves or the logic board. Unfortunately the only way to be sure is to replace.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Brand new craftsman remotes don't work when garage is closed
Yes, it seems to be a frequency issue.  Craftsman usually guarantees 50 foot range on your remotes.  Contact Craftsman, they will probably work with you to solve the problem.
Dec 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
