Question about Canon PowerShot A710 IS Digital Camera
Message Card Locked. Can't take picture - Canon PowerShot A710 IS Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 20, 2010
  • 51 Answers
On your card you have write protection clip!
you must slide up or down!
Posted on Jul 16, 2010
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
I have got a message saying Card Locked ! so it samsung p1000
remove the memory card ..on the memory card there should be a lock switch slide that one to unlock
Nov 17, 2009 | Cameras
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Message: "Card Locked!"
There is probably a tiny switch on your SD or MMC card. Switch it back to r/w.
Apr 30, 2009 | Canon PowerShot A410 Digital Camera
Card Locked Message
On the side of the SD card there is a slide button that has 2 positions, locked, or unlocked. Somehow it got slide to the locked position
Jan 22, 2009 | Vivitar ViviCam 5386 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Card locked error
While taking pictures the camera suddenly said card locked! So I purchased a new card only to get the same error message. I tried my card in my neighbors camera and it was fine. I am a bit antsy about this matter being that I only had the camera for 6 months
May 25, 2008 | HP Photosmart M527 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
