Question about LG WM2487H Front Load Washer
Water keeeps running and gives a code of FE on the display
    President:
  • 1,382 Answers
"FE" means Fill Error. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a
separatehot and cold valve. (they are the part that the hose screws onto on the machine.)To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
Thank you !!
Posted on Jul 16, 2010
FE code on LG washer.
The FE code is an excessive water supply if the water is continuously running into the machine it may be due to a failing inlet valve or stuck float switch since you mentioned the drain pump filter being changed it could be that the old filter was restricting the flow.
Apr 28, 2015 | LG WM Washing Machines
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
I have LG WM2487H*M and at begining of wash cycle when the water is filling, the FE code comes on and it keeps filling with water then drains the water when it reaches a level. What is wrong? I then shut...
Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically
LG WM2487HM series Service Manual Error Display
Oct 26, 2017 | LG WM2487HA Washer
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
In display shown FE
"FE" error code - over flow error
-Check water conection
-Check Water valve for proper operation
When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
Hope helps.
Aug 10, 2011 | Washing Machines
Code fe
FE Over Flow Error
If FE is displayed, the drain pump will operate to drain the water automatically.
(may be too much suds ...)
WM2277HW Service Manual HERE...
Or
Locate your service manual behind the kick panel of the machine.
FE means overflow condition.
Before replacing the fill valve sand or trash may have gotten into the tube going from tub to water level switch.
So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa!
Jan 12, 2011 | LG WM2487H Front Load Washer
My LG washer TROMM displays the code FE what does that mean?
Overflow error.
Water level frequency is over 213
If FE is displayed the drain pump will kick in to prevent flooding.
Might be a bad water valve OR it could be a clogged water pressure tubing (from tub to control)
Your tech service manual and some notes are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 19, 2010 | LG WM1812C Front Load Washer
FE errror code, can fill valve be replaced by owner?
FE Over Flow Error
• Water is overflowing (water level frequency is over 213).
0r
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | LG WM3431 Front Load Washer / Dryer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
FE code displays
Yes, the water valves are easy to locate and replace.  Just remove the top panel to get access to them.  There are 2 of them.  You need to know which one to replace before ordering the correct part from LG.
Mar 05, 2008 | LG WM2277H Front Load Washer
LG WM2487H Front Load Washer Logo
143 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
