Question about Samsung HL-R4667W Rear Projection Television
Samsung DLP 42" flickering green screen
Tv was fine yesterday. Turned it on today and the picture is green with horizontal lines and jumps or flickers. Any idea what's wrong?
  • 6 more comments
  • dwipman May 21, 2008
    My samsung dlp just started this flickering green screen problem. On all inputs. A ghost image of input can be seen through the green. The sound is fine. Also, when I display the menu screen it shows up clearly with all colors.
  • the twizz Jun 21, 2008
    I have a 50" Samsung DLP HDTV.  I purchased it in January of 2006, and just recently it started to flicker green.  This only happens on the cable input, not any auxiliary inputs, menus, or even picture in picture on cable have this problem.  The only solution i've found is to unplug it for a minute and then plug it back in.  It does come back occasionally though and is quite a pain.
  • jennybarron Jul 19, 2008
    I have the same problem. Question, is the DM board replaceable? What is approximate cost? Thanks for all your help.
  • Anonymous Nov 07, 2008
    I have the same problem. TV is only about 2 1/2 years old.
  • mmfarej13 Dec 10, 2008
    I turned my TV on this morning and the green/flickering almost "rolling" screen was there. Yesterday it was 100% fine. The only thing I dont understand is that it's like this from the cable box into the tv and the DVD player into the tv but the secondary connection from the cable box works fine no matter which input i use...and the other two wont work no matter what input i use. Any suggestions?
  • twalter430 Jan 15, 2009
    My problem is identical to "dwipman". I am curious if dipman got the problem fixed and if so, what was the final prognosis.
  • casimec Jan 20, 2009
    I have the same problem. TV shows pictures like in the included pictures. I remove power then after a couple of attempts to turn it on, it works fine, both HD and standard channels.
  • darkmage_59 Jan 19, 2012
    Exact same problem as that first picture.
    It is over multiple inputs, so one could rule out it being loose connections, as well, while I am not 100% sure, it shouldn't be the color wheel. I have had a shattered color wheel before and this is not the same situation.
    I imagine it's just the board that is going to fail. Everyone says it. Samsung builds these piece of **** terribly so that they consistently fail.
    If anyone knows the solution, please post.
Just unplug and plug back in. Worked for me.
Try it a few times.
May not work for everyone.
Posted on Oct 18, 2009
    Brigadier General:
  • 6,966 Answers
Based on your general description, it could be:
1. loose connection or cold solder on any of the connectors and/or boards specially those related to power;
2. heat related - at some point, the heat generated inside the unit could cause a component failure or worsen a cold solder/loose connection;
3. a component is about to fail - on most Samsung projection TVs, this would be the DM board. Exhibited symptoms would be screen flickers (white flashes) and in some instances after about a minute the screen gradually turns very very bright (almost white) from the bottom of the screen to the top.
Any of the above would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable venturing into a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 22, 2008
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 12, 2017 | Samsung Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HL-R4667W Rear Projection Television Logo
2,238 people viewed this question
Jerry Greenberg
Jerry Greenberg
