Question about RTO Atwood DSI-RV Water Heater-6 Gallon
My atwood water heater has spark and will light
My atwood water heater has spark and lights but goes to lock out. It seems that the computer is not sensing flame. I have cleaned all ground connections and changed ingnitor and gas valve last year.
  • RTO Master
  • 6,674 Answers
If you see a little short round (cut-out)diode-like piece inside a clear plastic sleeve that runs from wiring to thermostat terminal,(usually right under pressure relief valve) remove it from the thermostat terminal, as well as wiring from heater (take it right out of the circuit) and connect that wire directly to the spade connector where it was attached at thermostat, and now try it. They are a one shot cut-out, and if it went, no power gets to the system and by removing it, you will see if it's the problem or not. They are a safety device that if for some reason you get too large of a flame from water heater, and it feels the flame/heat, it blows and cuts off power. Should be replaced when you get a chance, but at least you'll know what the problem is. Let me know if that works please.
Posted on Jul 22, 2010
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add a comment as needed
Jun 02, 2013 | Water Heaters
Atwood g6a-be lights but goes out in 3-4 min.
mine is pretty new about a 1year in halve to two years old. i light with lighter it lights burns great then acts like propane cutts out then burns low then cuts out kinda acts like propane pressure cuts out in the valve but i can relight 30seconds later same thing. i have checked stove it burns great. is it in the waterheater propane valve. need help pease i need a cheap fix layed off right now. thank you dave
Sep 20, 2012 | RTO Atwood Water Heater - 6 Gal LP
Atwood water heater lights and goes off. i can hit the switch and will light and go off. it has spark ignition. lights fine but goes out in 2 sec.
Remove the wires at both ends of the thermal cut-off that is located in the little plastic sleeve below the pressure relief valve area and it's connected to spade connector on thermostat disc. Once removed, connect the female spade from wire to male spade on thermostat disc, and try to light now. If all's o.k. replace thermal cut-off as it is a safety feature to protect in case of flame up.
If not, get back to me.
Jan 16, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have an atwood water heater that won't stay light
I am having the same problem. Is your water heater a power vent?
May 02, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
230 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
