Question about Philips LFH-720
I have a Phillips, 393 Pocket Memo voive recorder. It runs then slows down or stops in both the forward direction but moreso in the reverse. Where can I take it in Winnipeg for servicing ?
5 Suggested Answers
  • 61 Answers
SOURCE: phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
Posted on May 17, 2010
  • 61 Answers
SOURCE: user manual for phillips professional pocket memo 198
Go to www.dictation.philips.com and find the support section for manuals.
Posted on May 18, 2010
alpug
  • 1961 Answers
SOURCE: Phillips Digital Pocket Memo 9500
Hello!
Does the green LED indicator lamp illuminates when you insert the Pocket Memo in the docking slot during recharging?
When the green indicator lamp do not lit when the pocket memo is inserted at the docking slot, then it means that terminal of Pocket Memo can not connect properly with docking station terminal.
If the green indicator lamp illuminates and after a few hours the Pocket Memo did work when turn on, then, it could be a faulty battery. You may try other rechargeable battery or non rechargeable alkaline battery for testing,
Posted on May 17, 2011
  • 145 Answers
SOURCE: Phillips Pocket Memo 381 The button
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Posted on Aug 16, 2011
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
Cannot run philips LFH9398 pocket memo on my mac
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
Where is the on/off switch for teh Philips 9350 pocket memo
Move teh 4-position switch to the stop position and push back the movable center part of the cap.This locks the 4-position switch and the device switches off.
MANUAL
Sep 29, 2010 | Philips Pocket Memo LFH9350 Digital Voice...
Hi, When i try and record onto the machine it does not run, it sticks, tried new batteries but no difference, machine is about 2 years old, David.
If ther is no drive, even in fast forward or reverse, the the belt may have come off the motor pulley. Otherwise you may have a hair wrapped around the tiny drive cogs under the turntable.
May 04, 2010 | Philips Pocket Memo 381 Handheld Cassette...
Phillips 281 pocket memo
Mar 02, 2009 | Philips Pocket Memo 281 Handheld Cassette...
Philips LFH-720 Logo
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
