Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 won't load drivers
Dell dimension 5150 won't load drivers from CD after I have reinstalled windows professional from installation CD. I've explored driver CD but can't work out how to install the drivers.
  • 487 Answers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Posted on Jul 16, 2010
I need to reinstall windows xp home edition i have the product code but no disk
I have used full install/ disk from other brands of computers (or other dell model numbers)to reinstall operation system (must be winxphome, dont worry about service pack, you can update). If you use any dell reinstallation cd, most likely you will not have to enter your key. If you use any other computer brand, or borrow someones xphome full install disk (not upgrade), then you will need to enter your key. Only problem of using for example emachine full install disk is that is will have emachine themes. Also you will likely need to down load other drivers. You are not lemited to to using reinstall cd for your model number. Good luck
Aug 28, 2012 | Microsoft Windows XP Home Edition Service...
My dimension 5150 does not burn cd's any more
CD/DVD drives are even less reliable than the cheap power supplies generally used in packaged PCs. Of two new, brand-name drives by Lite-On, one was DOA and the second ran for 2 days.
You can try removing (deleting) the drive from the Device Manager list, then rebooting. If the drive is at all usable, Windows should 'find' it and reinstall the driver needed.
If this doesn't work, the drive is likely dead.
Aug 14, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How would i reinstall windows on my pc
If the system shipped with a PC Restore partition and it is still intact, this this link should help
http://www.fixya.com/support/r3705089-restore_dell_system_original
if you do not have a valid PC Restore partition or a PC restore fails then it is back to the old fashioned way, from the Windows Media
Windows install is started by booting to the Windows CD/DVD, formatting the NTFS partition, then installing Windows to the drive. Once the Windows install is completed, the download and install the drivers listed for your system from Support.Dell.com
Jan 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller driver needed
You can download and install the required drivers from Dell's official website. Click on the link below:
Drivers & Downloads for Dimension 5150
On this page there are four files, download them all and install them. You should be able to use your network card after successful installation.
Note: If the above link is not working, go to www.dell.com. On the top right corner of the Dell's website click on 'Support'. A new page will open from where you choose Drivers and Download option. Next step is to choose your laptop model.
Oct 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No videon
it sounds like an issue of driver installation order. If not installed in the correct order, the drivers may not function correctly. The correct order is:
Desktop System Software
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
My suggestion is to do a system restore to the 1st available restore point (The one created at boot after you reinstalled) then install the drivers in the correct order. (NOTE: Before you can play a DVD, you will have to install the DVD player too)
Jul 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can not download drivers!!
Do you have the original CD's that came with the unit? they are blue and are the recovery cd's. they have all the drivers. Also, the windows 2K and XP OS may have a compatible driver. They reinstalling that driver. or do you have a modem? If your unit didn't come with one then you can purchase one cheap and dial up to the support.dell.com
May 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
156 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
