Question about LG enV Touch VX11000 Cell Phone
How do I view data on the micro sd card when it is installed in my phone
  • 206 Answers
By going to file manager! or by installing a software called X-plore and then using it to view your data!!
reply and rate!
Posted on Jul 16, 2010
Is it possible to restore deleted photos from damaged sd card?
Of course yes!
The iPubsoft Android Data Recovery can help you to recover all the data from android phone, including text message, contact, video, photo etc. How to Recover Photos from Android SD Card
Jun 20, 2014 | Toshiba Mobile Sd Card Pack Micro Sd/mini...
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have forget my memory card password which use in nokia 2690
If you lose or forget the password for your phone's memory card, there is no way to recover the password or access the data, even by taking your phone to a Nokia Care Point.
However, you may still be able to use the memory card if you can successfully format it. Formatting the card will not work in every case.
Formatting will erase all the data on the card.
To format you memory card:
1) Select Menu>Memory. Your phone shows the details of the memory card.
2) Select Options>Format memory card.
Thanking you
davevipul197
May 11, 2011 | SanDisk 2GB microSD Memory Card
My computer says I need to format the micro sd card from my cell phone, but I have used it for a year and I know it doesn't need to be formatted. Did the micro card die?
that is most likely. try to save any data from the card if you can still access it and then test it again on your phone. if the phone detects it, the format used may not then be compatible with the computer. you may need to use the software that came with your phone and install it on your computer to view/acess the contents of the card from your computer
Dec 31, 2010 | LG Cell Phones
I have an 8Gb ScanDisk Micro SD card that got corrupted is there anyway for me to recovery the data off of it
The answer is definitely Yes. You canrecover those deleted/lost pictures and videos from SD Card. But you have to rely on somephoto recovery software as it's the most effective way. Try Card Data Recovery. This program applies advanced algorithm deep scan your memory card and harddrives to seek for your lost pictures and video files. You may get the programhere:
http://www.card-data-recovery.com
Sep 29, 2010 | Garmin SOFTWARE, MICRO SD/SD CARD, EASTERN...
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
Samsung M310 Micro SD upload?
i do have micro sd and i am using a samsung unit. whe i want to grab a files from my computer. I am using a card reader/writer, insert my micro sd into the card reader, then connect it to the computer.
for playing/viewing just go to folder icon in your phone the choose memory card. thats is i can play/view my loaded files.
Jan 31, 2008 | Samsung SGH-E900 Cellular Phone
Need help
you need to install memory card in phone then attach a data cable specfically for your phone (available at cell phone dealer) into phone and the other end to the usb of the pc if our phone came with software load it on pc then use the software to transfer the music files from your pc to your phone.
Jan 09, 2008 | Electronics - Others
LG enV Touch VX11000 Cell Phone Logo
99 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
