Question about Microsoft Windows XP Professional SP2
When I switch on my computer, I get a message your computer is locked. How do I unlock?
    Novelist:
  • 144 Answers
If it is locked, you can go Ctrl-Alt-Delete on your keyboard.
that is, you hold down the CTRL key, then while holding that key, press Alt, and while both those keys are down, press Delete, and then release all 3 keys.
put in the password that you log into the PC with.
and the PC should now unlock and present your desktop.
Posted on Jul 16, 2010
Why does my 2004 Chevy Silverado lock and unlock while in drive? When turned off and no keys in ignition the drivers door will unlock on its own a short time later.
Gremlins ! HA HA HA sorry ! First off a little bit on how they work an what all is involved in making them work ! There are a few control modules in the mix , switches ,relays etc...
Door Lock System Components
The power door lock system consists of the following components:
The driver door module (DDM)
The passenger door module (PDM)
The body control module (BCM)
The driver information center (DIC)
The rear door lock switch
The door lock relay
The door unlock relay
The liftgate lock relay--utility vehicles with liftgate only
The reversible door lock actuators in each of the doors and liftgate
LOCKS 20A fuse (rear lock/unlock relay supply voltage)
ECC 10A fuse (liftgate lock relay supply voltage)
Door Lock System Controls
The power door lock system can be controlled by any of the following:
A power door lock or unlock switch activation
A keyless entry transmission
An automatic door lock function
A delay lock function
Door lock cylinder switch activation
Lockout Prevention
An airbag deployment
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
The DDM (driver door lock actuator).
The PDM (passenger front door lock actuator).
The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
The first place to start is have a factory or equivalent scan tool hooked up , one that can read BCM DTC'S - diagnostic trouble codes ! This could lead to a fix faster ! Watch these three videos !
Door Locks Go Crazy 1
Sep 16, 2015 | Cars & Trucks
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
2009 GMC Envoy - power door locks, power windows, fuel gauge not working, dome light isn't working
Do you know anything about automotive electronic's ? computer controlled systems ? There is electronic control modules in side the doors of your vehicle that control the operation of the windows an lock's , plus the instrument cluster is a module too . Your vehicle has about 10 different control modules and thet are all hooked on a serial data communication network ,to share info. The fuel tank sending unit in the gas tank is wired to the PCM - engine computer , The PCM sends fuel level info to the gauge in the instrument cluster on this serial data network . Your best bet ,take an have the vehicle checked out by a qualified repair shop .
• Driver Door Module (DDM)
• Passenger Door Module (PDM)
• Liftgate Module (LGM)
• Door lock relay
• Door unlock relay
• Body Control Module (BCM)
• Reversible door lock actuators in each of the doors
• LR/RR LOCKS 10A fuse (relay supply voltage)
• Door lock switches in driver and passenger doors (switches are integral components to the DDM and PDM)
Power Door Lock Operation
The power door lock switches are integral components of the DDM and PDM. The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The modules which activate the power lock motors are:
• DDM (driver door lock actuator).
• PDM (passenger front door lock actuator).
• BCM (both rear door lock actuators).
• LGM (liftgate door lock actuator).
The DDM, PDM and LGM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The modules probably have DTC'S - diagnostic trouble codes stored , these would point a auto tech in a positive diagnostic direction .
Oct 30, 2017 | 2009 GMC Envoy
I have a 08 chevy avalanche the driver side front and rear door locks won't work when I use my keyless entry button or on the inside driver panel. Could it be a fuse? Passenger side works fine I try...
Do the power windows work ? DDM - driver door module fuse 15 amp - location is the instrument panel fuse box , plus LT DR circuit breaker 25 amp. Circuit breakers rarely go bad . The power locks are controlled by electronic's .The passenger side has another power supply ,that's why they still work .
• The driver door switch (DDS)
• The passenger door switch (PDS)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock/unlock relay (LBEC)
• The reversible door lock actuators in each of the doors and liftgate
The front power door lock switches are integral components of the driver door module (DDS) and passenger door module (PDS). The switches are 2 position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDS or PDS. The DDS or PDS monitors these inputs and sends a LAN message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the LAN message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock/unlock relay and also send a LAN message to the DDS and PDS to perform the appropriate function.
• The DDS (driver door lock actuator)
• The PDS (passenger front door lock actuator)
• The BCM (both rear door lock actuators and cargo door/liftgate)
The DDS and PDS are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and endgate doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
It's possible you have broken wire or wires inside the flex boot from the body of the vehicle to the driver's door . This happens a lot .
Fuse Block - I/P instrument panel
Left of the I/P behind the side trim panel
Mar 04, 2018 | 2008 Chevrolet Avalanche
Screen says write protect
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't do it, try another card.
Aug 05, 2011 | GE A1255 Digital Camera
Message reads "card is locked." After
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 09, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Photo card locked and can not take pictures.
There should be a tiny slide switch on the side of the card. Merely slide this switch to the other "unlocked" position.
May 28, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Microsoft Windows XP Professional SP2 Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
