Re: Mitsubishi WD-6267 DLP problem
A while back, I had posed the following problem: That my Mitsubishi WD-62627 DLP projection TV goes black & white after it's warmed up. The solution offered was that there was most likely a problem with ICs. What I've found since then is that if the back of the set is removed and a small floor-type fan is placed against the chassis blowing a steady stream of air, that the problem doesn't occur. I have just received a Mitsubishi service manual for this set but it's sparse on troubleshooting. Sounds like a component that's getting too warm, such as a capacitor, transistor, IC, etc. Based on what I've described, does anyone know which PCB's and/or components I should be looking at? Could it be a problem with the light engine itself?
Regards,
Greg
4 Suggested Answers
  • 1153 Answers
SOURCE: Have two Mitsubishi WD-62627 HDTV's.
The first one sounds like one of two bad boards. If you get color here always(component input (Y Pr Pb) then it's the terminal 2 PCB, and if not it could be FMT board. Either way you would need further checks to make sure. For the other set i would need email for instructions, because of broad range of problems!
Posted on Mar 12, 2008
bestdarngood
  • 3037 Answers
SOURCE: Re: Mitsubishi WD62627 projection TV issues
Not off hand, but you can call them and ask for the part number and order it at the same time
1-800-332-2119
Let me know if you need any other help
Posted on Mar 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: green convergence, bad IC?
C8011 could definately cause the problem you are indicating as one side of that capacitor is tied to the postive feed for Red horizontal in IC8001 ( STK392-560) and the other is tied to the Green vertical return . I would replace that along with the IC as the IC is sure to be weakend if that capacitor has shorted. Let me know if you need further assistance.
Posted on Apr 08, 2008
I need manual for mitsubishi dlp tv 62 inch model wd-62627
Owner manual or service manual?
Try to Google the model number for either or visit the Mitsubishi site for the owner manual.
May 21, 2012 | Mitsubishi Televison & Video
Tip
Fix for Mitsubishi WD-62627 going black and white
I found the solution to my problem and it has worked on two different Mitsubishi WD-62627 DLP rear projection HDTV's both with the same problem of the pictures going black and white after the sets had been on for about 20~30 minutes. I suspected that the color wheel might be the culprit. I removed the color wheels from both light engines and flushed out the back sides (where you can see the pulse coils in the back of the color wheel motor in the picture below) liberally with Ronsonal lighter fluid, which is basically naptha. I used lighter fluid for years in camera repair to flush out micromotors that would slow down or bind over time. The Ronsonol evaporates quickly and does not leave a harmful residue, however, I blew each one out with compressed air to make sure there was no liquid left. I then cleaned the glass on the color wheels, installed them back into the light engines, and installed the light engines back into the TV's. Both have been working fine for several weeks now. I do not claim this technique as a panacea but it has worked for me.
Greg
on Jun 09, 2008 | Mitsubishi WD62627 62" HDTV
How to hook up my dvd
Check the back of the tv, there will be a collection of plugs and they will be marked AV1 AV2 etc...They will be color coded and yellow is Video, and red/white are audio.
Mar 06, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Mar 20, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Have two Mitsubishi WD-62627 HDTV's. One will go all black and white after unit has been on a while; shutting it off and turning it back on will correct problem for a while. The second WD-62627 has seven...
Mar 12, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
