Question about RCA EZ 105 Camcorder
Ok i went on vaction , took few pictures and the screen went fuzzy so i decided to turn it off and when i return it back on , i got two lines across the middle and white back ground , it still takes pictures and records but does not show anything but lines and white back ground , any idea how fix this.
techman
  • 3130 Answers
SOURCE: Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Posted on Oct 14, 2006
  • 556 Answers
SOURCE: can only see half the picture
your problem is in vertical output section.
the ckt which is connected to vertical output section is called feedback ckt.
please check.
1 loose contact in feed back ckt.
2 mostly this problem is due to electrolytic capacitor failure.
3 vertical output  IC or transistor failure.
4 check for proper supply to vertical output.
5  low value resistor failure in v/output ckt  (.in rare case)
IF YOU ARE NOT TECH PERSON PLEASE TAKE HELP.
  1. hope this will help.
Posted on Oct 10, 2007
nfandres
  • 168 Answers
SOURCE: RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Posted on Aug 16, 2009
  • 157 Answers
SOURCE: thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Posted on Sep 02, 2009
Testimonial: "good suggestion."
  • 8457 Answers
SOURCE: rca 61in. tv is showing
Ur convergence is dead.Require convergence kit tv model,replace parts.
Posted on Sep 09, 2009
My Powershot 410's LCD screen suddenly went fuzzy,
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 29, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
When switched on, display reads "In synchronized monitor mode"
Cycled through display options, still couldn't get viewfinder image. Checked images already on card, and they showed OK, so screen operating properly. Went back to viewfinder mode, got lots of horizontal lines across screen. Realised I could do no more, so took camera to shop it was bought from, who checked it and said it had an electronic problem that needed professional repair facility, so camera has gone for an estimate of repair cost.
May 07, 2009 | Ricoh Caplio R4 Digital Camera
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
I will to know the code for the precision Tv
Hi, I have a sharp 32sf56b. sound OK. Picture went dim and fuzzy. Clears up a little when turning brightness control all the way down. Picture has no snow. Can see fate vertical line on screen
Mar 08, 2009 | Televison & Video
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Jan 11, 2009 | Televison & Video
Tv turns on get piture then get fuzzy whit line then goes off pleaze help me
i had this same problem, there is a common fault with these models, and the onyl way to fix it is to get a chip replaced in there...cant remmerb the name of this, but it cost me about £30, now the tvs fine
Oct 31, 2007 | Televison & Video
Lines on screen
Hi, I have the same problem with my sony DSC-S700. I think someone drop it, and it took pictures with horizontal line specially outdoor. I noticed that the lens shutter does'nt open and close. All I did was to tap on the lens several times and everythings back to normal. I so happy my camera is working again. Thanks to your idea. Brenton
Sep 24, 2007 | Kodak EasyShare Z612 Digital Camera
RCA EZ 105 Camcorder Logo
59 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
