Question about Voyetra Turtle Beach Turtle Beach Ear Force X1 Headphones
Xbox 360 it makes sound but the picture dont come in i hook up all the connector to the right av jackes but it still wont show no picture still
  • Anonymous May 20, 2008
    sound comes on but picture is a snowey efect
  • Anonymous Oct 10, 2008
    I just have no picture at all.
  • 44 Answers
If ita an older model xbox360 it might be the gpu solder point are not making contact there are a few solution to this problem 1st you might want to google x-clamp fix 2nd if its under warranty then send to ms 3rd check if you dont have your composite cable turn on to hd if you do not own a hd tv feel free to mail me psx2king@gmail.com
Posted on May 14, 2008
Maybe your tv isnt hd and you need to switch it on the bottom of the power cord (the end nearest the xbox) i had this problem hope it helps
Posted on Apr 28, 2008
Why doesn't my XBox 360 show a picture on the tv
Most likely a damaged AV output socket , possibly lifting of the solder joins,
Jun 11, 2014 | Microsoft Xbox 360 Console
My sounds works and so does my directtv but no picture will show up for my 360 i bought a new av cord and it still wont work how do i fix it
Are you on the correct channel or input for the xbox 360? Also check your av cable to see if it is on the hdtv or regular tv. You can move the switch to make the adjustment. It may be how you have set up your xbox 360 cables and the directv box cables to the tv so you should consult your tv manufactory for the correct guide on setup.
Dec 22, 2010 | Microsoft Xbox 360 Console
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Xbox 360 with no picture
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
Apr 07, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
NO PICTURE
Homerunkevin, Right go to the back of the xbox and on the AV cable there is something that looks like a button. Switch is across and try again. I had the same problem with my Xbox 360 then i figured that out.
Good luck,
Ben
Feb 02, 2009 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture
Try looking on your AV Cable there is a setting for HDTV and TV if you have a High Definition tv use that setting but by the sounds of your issue i would say you dont and would go with the regular TV setting. Its right on the neck of the AV cable where it plugs into the game console. Let me know if this works for you.
Dec 26, 2007 | Microsoft Xbox 360 Console
I have SOUND but no PICTURE
Check the AV plugs those are the red white and yellow plugs make sure that the yellow is plugged into the yellow circle on your tv and red to red and white to white, unless your on hdtv. if there plugged in make sure it is on the right channel probably 3 or 4 if those dont work change it to video mode or input mode.
Dec 25, 2007 | Microsoft Xbox 360 Console
Open Questions:
Voyetra Turtle Beach Turtle Beach Ear Force X1 Headphones Logo
106 people viewed this question
Top Voyetra Turtle Beach Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Voyetra Turtle Beach Audio Player and Recorder Expert? Answer questions, earn points and help others
