Question about Microsoft Computers & Internet
When my PC ''died'' a few months ago, I got a new computer which has a 64 bit operating system. None of my 32 bit applications will run on it. Most of the apps I used are relatively expensive to repurchase in 64 bit versions. Does anyone have suggestions? (and PLEASE be very specific - I'm not very computer literate). Thanks, Pat
  • pcradylady Jul 16, 2010
    Thanks for the quick response; if I install the 32 bit system, will I have to reinstall the entire computer? - all apps, data files, etc? THANKS!!
    Novelist:
  • 144 Answers
I suggest taking the 64Bit Disk back to the shop, and ask for the 32bit version, then reinstall windows with this version.
64Bit windows will have this problem , if you do try to use legacy applications on it.
it is the nature of the beast.
you can try to run the program in compatibility mode, by right clicking on the executable, and going to the properties window and ticking the Run in Compatibility mode. sorry i am not near a 64bit machine at the moment, so cannot tell you the exact wording.
Posted on Jul 16, 2010
Testimonial: "Very good idea"
Can you run office 32 bit on a windows 64 bit operating system?
You have 32-bit Office installation package (CD/DVD/file) and 64-bit Windows operating system. Is it correct?
General answer is YES, I can install a 32-bit application on 64-bit OS. I have exactly same situation in my laptop. Both 32-bit LibreOffice and 32-bit MS Office are installed on W7 & W8 laptops and work well.
But NO vice versa. The 32-bit system does not allow to install 64-bit application. The 32b system does not support 64b instruction set required for 64b applications.
My experience is confirmed by many other users:
Office 32 bit to Windows 7 64 bit
Jan 29, 2014 | Microsoft Windows 7 Professional for PC
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I have an other brain teaser! bought a laptop (sony vaio) it had vista on 32bit.i upgraded to win.7 ultimate. 32bit. could it be maybe it is a 64 bit base? nota geniouse but could this be why my bat
Beginning with the release of Microsoft Windows Vista, 64-bit operating systems are slowly becoming extremely prevalent in today's market. 64-bit operating systems are poised to eventually replace 32-bit operating systems entirely. At the present however, 32-bit applications still vastly outnumber 64-bit applications. Luckily, 64-bit operating systems are capable of running 32-bit operating systems. In 64-bit operating systems, 32-bit applications are installed to a second program files folder, named "Program Files (x86)." Programs installed in the x86 folder can be initialized just like programs installed in the regular Program Files folder.
Open the 32-bit programs folder. Go to Start > Computer > Local Disk (C:), then click on "Program Files (x86)." Open the desired program folder. The executable file for the program will be located inside the folder. Double-click on the file with the ".exe" file extension. As an example, for the QuickTime program you would double-click on the "QuickTimePlayer.exe" file. You have now successfully run a 32-bit application in your 64-bit operating system. Hope this helps.
Dec 08, 2012 | Computers & Internet
My computer is telling me I can not run an x86 build of this utility on a x64 platform. I am running windows 7. What do I have to do to be able to run this program for the new Futura CE-150
x86 means 32bit operating system , x64 means 64bit operating system.Windows is divided into to categories 32 and 64 bit. In your case you might be trying to install 32bit operating system's software or a application in an 64bit operating system running machine. If you are getting the above mention error message than it is clear that your window 7 is 64bit operating system and a 64bit operating system doesn't support 32 bit's software. You only can install software or application you are meant for 64bit supporting.
If you want to know more about 64 and 32 bit CLICK HERE
GOOD LUCK.
Jul 15, 2011 | Singer CE150 Futura SewingandEmbroidery...
Not Enough Memory to run Microsoft Office Excel. Please close other Applications and try again..
Excel running on a 32 bit PC and using a 32 bit operating system can only address 2 Gb of RAM. If your machine has a 64 bit processor (these were being shipped over 5 years ago) it will be possible to install a 64 bit operating system such as Windows XP 64 bit or Windows 7 64 bit. It has been claimed that an Excel 2010 spreadsheet, running on a 64 bit machine and using Windows 7 64 bit, was able to load and use a database with 100 million records.
If you are unable to do this then I suggest that you examine what your machine is running at the same time as your spreadsheet and if any part of the spreadsheet can be off-loaded. By the latter I mean can any of it transferred to another Excel file?
Are you using any links on your spreadsheet, if so can the links be converted into data, e.g. a link to a lookuptable could be converted to data (copy, paste-special, value) and this remove a significant amount of processing load.
Oct 18, 2010 | Microsoft Excel for PC
I have American Heritage Dictionary cd rom but when I tried to install it into my new laptop which runs Windows 7 64-bit, it showed that the program cannot be installed in 64-bit system. How can I install...
It is not possible to install 64 bit application in to 32 bit machine, as it has been designed for the 64 bit operating system which has n different architecture.
better check with the product site for 32 bit compact ability.
Oct 15, 2010 | Computers & Internet
I have just purchased an new computer and am running windows7 on a 64bit machine. I have tried several times to install the Kodak software from the disk provided with my printer which worked OK on my last...
32 bit and 64 bit drivers are not compatible. So for 64 bit operational system you have to install 64 bit drivers for your Kodak Easyshare 5100. I found link for you:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
I am strongly suggesting uninstall everything what are you installed ignoring warnings about incopatibility before installing proper drivers! Good luck! :-)
Sep 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Can i installed 32 bit applications on 64 bit processor?
The answer to your question above is Yes, you can install 32-bit applications on a 64-bit desktop/laptop. Please note 3 things:
1. The 64-bit environment will be determined by both the CPU and OS being 64-bit capable. If one of the them is not, then the system will not perform at the 64-bit level.
2. 32-bit applications can be installed on a 64-bit OS and they will function properly - but only at a 32-bit level. They will not take advantage of the 64-bit environment until the application is certified for 64-bit.
3. 64-bit applications cannot be installed on a 32-bit environment - they won't run at all.
Aug 25, 2010 | Microsoft Visual Studio 2005 Standard...
I need a Master Cook software that will work with Windows Vista 64 bit
On less-widely distributed programs, you may never find 64 bit version.
I'm not familiar with Vista but previous versions of 32 bit operating systems allowed 16 bit applications to run under an 'emulation' mode of previous operating systems; i.e. Win 98 could emulate Win 95.
Check your Vista 'Help' for 'Emulation' or '32 bit applications.'
I think you'll find what you need.
Aug 28, 2008 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
