Question about Sharp AR-M205 Copier
Need to replace drum and developer maintainance
    President:
  • 2,072 Answers
If you are getting that message and the prints and copys still look good , just do this.
Press # * C * and that will put the machine into diagnostics.
Enter the number 24 and press start, That will get you into maintenance resets. Then enter 06 , press start, then while still in 24, press 7 and it will reset the developer.But 24-06 and 24-07 should clear the count and return the machine to normal. The developer and drum will normally run longer than indicated by the counter.
Posted on Jul 16, 2010
Konica minolta bizhub 206 maintainance service m2 how to set this problem
Did you clear the counters for the drum and developer FIRST if not get a new drum and new developer as both are replaced at the same time. As the machine uses the counters to determine a a new unit and adjust certain voltages to certain units accordingly. Other wise machine thinks it is old when it is new and causes image issues and codes
Apr 23, 2017 | Konica Minolta Office Equipment & Supplies
Having error code cof-32 on bizhub 211 printer
Did you clear the counters before you replaced the drum and developer? If not Replace the drum and developer again. This time clear the counters for the drum and developer before. This done as such
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Oct 27, 2015 | Konica Minolta bizhub Office Equipment &...
The error show replace drum unit and developer but when i replace it with new drum unit and developer the error still shows drum unit and developer need to change?
you did not do it right first you run drum dry, then clear the counter then install the new drum and developer, now get new developer and drum and follow the service manual drum dry first then clear counters then run TCR adj. then run gradation procedure Better to get a tech to do it.
Aug 13, 2015 | Konica Minolta Bizhub 423 Copier Printer...
How to clear counter of Minolta bizhub 163.At present its showing ERROR "MAINTAINANCE CALL 2"
Need to have the drum and developer replaced first. Then clear the counter. Not replacing the drum and developer and resetting the counter will cause image problems and codes due to the fact the copier uses the counters to determine voltages to certain units. and is the only way the machine has new parts. You reset the counters and not replace the parts, then the voltages will be set for new parts when in fact parts are old.
Jan 15, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 3010 cof 32
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
May 16, 2014 | Minolta Office Equipment & Supplies
Error code c2557
Have you had the developer and drum replaced or does the screen say Replace PC Drum? . One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Mar 13, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
HOW CAN I REMOVE C2557 ERROR CODE FOR MY BIZHUB 350
Have you had the developer and drum replaced or does the screen say Replace PC Drum? . Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Aug 23, 2013 | Minolta bizhub 200 All-In-One Printer
Copier flash maintainance call
Needs the drum, drum blade, developer replaced and a good interior and exterior cleaning. Call a service center to get service.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have the problem in my copier the error is c-0f33, can you help me
Have you had the developer and drum replaced? Need to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
try this site for developer and drum
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jul 02, 2010 | Minolta DiALTA Di520 Laser Printer
Install mk
install MK means replace the maintains kit . maintains kit is belongs to drum ,developer , drive gears ..... after 250000 print it asking to replace all the things ....... this is not harmful the printer it will work fine don't worry about the install mk....
Nov 18, 2009 | Kyocera Mita FS-3830N Laser Printer
Sharp AR-M205 Copier Logo
169 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
