I've got nexstar lite external 2.5 hd enclosure with 160 gig hd inside but it would not work because I'm running win 7 so please show me how to fix it.regard paul
  • 6,826 Answers
Windows 7 is not supported by the Nextstar Lite external 2.5 hd enclosure. It's a windows XP supported device.
There is no support on this product for Windows 7.
Posted on Jul 16, 2010
  • gjldev Jun 22, 2011
    It works on my laptop with Windows 7, but not on my Desktop with Windows 7. WTF??????
My NexStar CX external drive worked fine until now. When I powered it up this time the power adapter turns a solid blue. Then when I turn the external drive on, the power adapter starts to flash a weak...
I had same symptoms. After wasting two hours, I finally found the HD not making good contact within the enclosure because I have not screwed it in with the frame. It must have broken the connection while I was handling the enclosure. So my suggestion is to check the simple stuff first - connections and loose cables, particularly within the enclosure.
I needed no drivers for my Windows XP Pro.
Jul 19, 2012 | Vantec NexStar 3.5in External Hard Drive...
I bought the vantec nexstar sx model nst-285u2 and it wont work on windows 7 pro 64bit and i cant find a driver that will work for the software
I just bought the 260U2, same deal. Take it back and demand a discount for one that works. Bring your hard drive and confirm it in the store.
Apr 27, 2011 | Vantec Nexstar-SX NST-285U2-BK 2.5 Inch...
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
CPU won't read it im running xp
Ok, here's some step by step instructions.
First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
May 09, 2009 | Vantec NST-285S2-BK NexStar SX 2.5"...
External drive not showing up
Have you gone into disk management?
If it is vista, right click on my computer, and manage, disk management.
Check and see if the disk shows up there. If so, you will probably need to format it.
Vista has it's own format, and does not like the usual XP disk. I just went through this.
Apr 07, 2009 | Acer Aspire 5610-4648 Notebook
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Windows xp drivers for seagate ST3160203U2-RK
Drivers are not needed for this Ext HDD.
If you go to your Computer Management>Storage Devices,you will have to assign a Drive letter for it to show in your "My Computer" as a External Hard Drive.
Also ensure that drive is set as "slave" and do not connect until computer is booted to Desktop.
All changes will take effect after reboot.
Feb 02, 2008 | Computers & Internet
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
238 people viewed this question
k24674
jasbo
jasbo
