Question about Kenmore 73952 Gas Dryer
What tool do I need other than a Phillips screwdriver, to put a new handle on my Kenmore HE3 gas dryer? There are 4 screws with heads o don't recognize.
  • 171 Answers
Those are hex or star heads available at any good hardware store..
Posted on Jul 28, 2010
Inglis belt replace
1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 6) Next is to remove tension from the belt so that you can remove the drum. To do this simply reach under the drum and pull the idler pulley in the direction of the closest wall. This will give you the slack needed to take the belt off. 7) carefully pull the drum out. I usually do this by lifting up on the left from the top, using it as a handle. This is helpful because it also prevents the belt from getting snagged on anything underneath.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Whirlpool Dryers
How do you fix a dryer belt for a moddle 6670269
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
May 14, 2012 | Kenmore Dryers
How do i open the top to a kenmore dryer
May 11, 2012 | Kenmore Dryers
Kenmire 80 series dryer drum doesn't turn
May 05, 2012 | Kenmore Dryers
Where are my dryer belts located
May 02, 2012 | Kenmore Dryers
Need to remove bad lamp from the HC100 projector
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the projector.
Pull the lamp box out of the projector slowly. If it is pulled out quickly, the lamp may break scattering
glass fragments.
Do not spill liquid on the removed lamp box or do not place it near any flammable object or where children
can reach to prevent injury or fire.
6. Load a new lamp box securely into the projector in the right orientation.
7. Put the handle back to the original position.
Make sure that the handle is locked.
8. Tighten up the screws (c) using a Phillips screwdriver (+).
9. Tighten up the screw (a) using a Phillips screwdriver (+) to secure the lamp cover.
Jul 20, 2011 | Mitsubishi HC100 DLP Projector
What tools are needed to put this BBQ together
Basically, you'll need 4 hand tool. A flat blade screwdriver , a Phillips Head Screwdriver, an Adjustable Wrench & Box End Wrench. If you are real careful, you can substitute a Variable Speed Drill Driver for the Phillips Head Screw Driver. Be careful not to over torque the screw.
Hope this helped you and Happy grilling!!
Jul 09, 2011 | Weber Genesis E-310 Gas Grill
Kenmore gas dryer heats for several minutes ,then goes cold
I'm haveing the same problem with my frididaire gas dryer. I replaced the ignitor and cleaned the inside parts with a vacume and still having similar problems as yours. I think I will replace the temp. sensor that is attached to the flame tube inside the dryer next. To gain access to the inside parts you will need a putty knife to release the top panel. Just slide the putty knife along the top seam in front of the drryer. There are 2 clips that realease the top peice. With the top lifed up you will see 2 phillips head screws attaching the front panel to the dryer. Remove those screws and lift upwards and the front panel will lift right off the unit.carefully place the front panel to the side without damageing any wires attached. Then all your gas assembly parts will be visable in the bottom left cornner of the unit.
hope this helps,
Aug 23, 2009 | Kenmore Dryers
Broken door handle
remove 5 screws from door hinge,, lay complete door on top of dryer know remove all phillips screws(cross) and that its
Jan 01, 2009 | Kenmore Dryers
Door handle
I bought a handle and took a chance that I would figure it out. It turns out to be pretty simple. Open the dryer door and you will see 10 phillips head screws on the back of the door. There are also torx(star shaped) screws. Remove only the phillips head screws. This will separate the plastic outer ring from the door. On the back of the plastic ring are 2 screws that hold the handle. Remove the screws, replace the handle and put the ring back on the door. Put the 10 screws back and your done.
Nov 09, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
