Question about Toshiba 13A21 13" TV
I cannot manually set the tv to Auxillary. How
I cannot manually set the tv to Auxillary. How can I do this?
Sharp 13J-M100 owner manual
you need to get the tv to an auxillary channel...this is accomplished by the remote...try getting a replacement thru eBAY or possibly buy a universal remote.
Aug 28, 2014 | Sharp 13J-M100 TV
How to turn on/off the fronr and rear auxillary inputs? I used to be able to do that but l've forgotton. Any help is sppreciated! e:mail guitgeo59@arrnet
Go to it input selection menu window. There you can select the input you want. Refer its user manual. Click here to download the user maual.
Feb 26, 2013 | Toshiba CN27E90 27" TV
Orion TV Manual
What is the exact model number? You can get this detail at it back cover.
Aug 22, 2012 | Akai Televison & Video
Lost our original remote and now cannot get into auxillary manually. Cant find a universal remote that works. Please help! Many people on this site say there is someway to get it to AUX setting manually...
Try connecting this TV to a VCR or DVD player. Then press channel two and continue to press channel down. See if this will work. Also...if you have an older model Emerson TV remote, it will operate the Orion TV. Let me know if this will work!
Dec 12, 2010 | Orion1934 19" TV
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Ldc/hdtv hook-up
Salutations kajeong,
Normally there are not connections on a television to provide "auxillary" speakers to the original unit. Looking at the owners manual for several of the Aquos units it appears that it would have audio outputs, but these normally wouldn't be available for things such as speakers.
Normally the only way to get what your looking for done is by using a separate amplifier and speaker set and controlling the volume for that.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 11, 2008 | Bose FreeStyle TV Speakers
Auxillary without a remote
I would try going to the manufacturers site and downloading the manual if you don;t still have yours.
Dec 29, 2007 | Sylvania 6419TE 19" TV
Using the auxillary setting
You'll need to turn the auxiliary function on in the setup menu. Press Source to put the unit in Standby, then press and hold the Menu button for at least 1 second. Press the control switch toward AM or FM until the AUX setting comes up, then press the control switch toward <<< or >>> to change the setting to ON. You can download a user's manual here: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Jun 23, 2007 | Kenwood KDC-MP205 CD Player
Auxillary input
There is a setting to called `Aux On' and 'Aux Off' on PAge 27. MAybe it is set to off.
Jun 01, 2007 | Kenwood KDC-MP528 CD Player
Toshiba 13A21 13" TV Logo
16 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
