Question about Panasonic RPHC500 Headphones
Noise coming from left headphone when OPR is on
Headphone Port
try a new set of headphones.. if that doesnt work then i would see if you can see any dust in the headphone socket.. maybe try putting a coctail stick in and see if anything comes out.. please be gentle though. if nothing comes out you could need the headphone socket repairing
Apr 06, 2014 | LG G2 Black D802 Factory Unlocked 5.2"...
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
I have a sony w252 mp3 player and i erased every thing in it but its memory still seems to be full... how can i format the all memory....
Formatting is available only while playback is stopped.
If the OPR lamp lights red due to low remaining battery power, the player cannot be formatted.
All data stored on the player will be erased.
The Content Transfer software included with the player will also be deleted.
If necessary, download Content Transfer from the customer support web site.
The settings of shuffle playback, playlist playback, ZAPPIN playback, and AVLS (volume limit) also return to their defaults.
Follow the steps below to format the Player.
1 Unite the left and right parts to turn off the player.
2 Separate the left and right parts.
3 Press and hold the jog lever for about 15 seconds until the status lamp blinks quickly. Release the jog lever. The OPR lamp lights red.
4 Move the jog lever forward or backward within 30 seconds after the OPR lamp lights red. The status lamp turns off. The OPR lamp lights alternately green and red each time you move the jog lever.
5 Press the jog lever while the OPR lamp lights green. The OPR lamp blinks green quickly and formatting is executed. When the OPR lamp turns off, formatting is complete. If you press the jog lever while the OPR lamp lights red, or if 30 seconds have passed, formatting will be canceled.
Thanks for contacting FixYa.
Apr 08, 2011 | Sony NWZ-W252 MP3 Player
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
It is not switching on.when i set it for charging it show full charging but when i turn it on it shows red light and 3 time tone is heared thn it become off.....please help me
Even i also had a same problem after format a player its working good. Format your player and put songs again. thats it.
Notes:
  • Formatting is only available when the player does not playback.
  • If the OPR lamp lights red due to low remaining battery power, the player cannot be formatted.
  • All data stored on the player will be erased.
  • The Content Transfer software included with the player will also be deleted. If necessary,
  1. Unite the left and right parts to turn off the player.
  2. Separate the left and right parts.
  3. Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
    Release the jog dial. The OPR lamp lights red.
  4. Rotate the jog dial within 30 seconds after the OPR lamp lights red.
    The status lamp turns off. The OPR lamp lights alternately green and red each time you rotate the jog dial.
  5. Press the jog dial while the OPR lamp lights green.
    The OPR lamp blinks green quickly and formatting is executed. When the OPR lamp turns off, formatting is complete. If you press the jog dial while the OPR lamp lights red, or if 30 seconds have passed, formatting will be canceled.
have a nice song for ever...!!!!!!!!!!!!!!!!!!!!!!!!
Apr 11, 2010 | Sony Walkman NWZ-W202 MP3 Player
Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Mar 29, 2009 | Audio Players & Recorders
Left Headphone not working
well maybe because, you to cheap to by good headphones
Mar 04, 2008 | Sony MDR-G42LP Consumer Headphones
Panasonic RPHC500 Headphones Logo
115 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
