Question about Tascam US-144 Sound Card
I dont have the disc for my tascam us-144 - Tascam US-144 Sound Card
  • 10,319 Answers
Download this driver so it will work for you
http://www.driversbay.com/drivers/sound-cards/tascam/us-144mkii/
Posted on Jul 16, 2010
djnick989
  • 1067 Answers
SOURCE: Cubase software does not recognize my TASCAM US-144
do u have usb 2.0 prts in back use not front of pc those 1.1 ports ok cheak drivers on all tell your master sound drivers defult to tascam see what happends
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: what cables for yamaha keyboard psr295 to connect with tascam 144
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Posted on Sep 10, 2008
SOURCE: Can't get a signal with my Tascam US-144
Make sure the Tascam is has updated drivers. The latest driver is Version 1.12. Something that helped me as well was to re-route my sound card to the Tascam. Meaning to have Windows, use the Tascam as the sound card for the computer.
This is the advice I followed from a forum it helped me alot!
I eventually disabled all other sound cards on my PC. In my case it was simply the integrated soundcard on my motherboard. I did this in the bios setting. I also uninstalled the drivers for it, just in case. I was having problems hearing anything in Cubase before I did this.
I set the US-144 as my default sound device in Windows (Control Panel>Sounds and Audio Devices>Audio)
I'm not sure what you are trying to record so I will give you a guitar example.
Guitar plugged directly into LINE/GUITAR IN R using the 1/4" jack with the switch above it in the GUITAR position. You can use the INPUT R dial to adjust the input volume for this channel. The SIG/OL light should turn green when you strum the guitar.
The US-144 is plugged into a USB 2.0 port on the PC.
Speakers are plugged into the LINE OUT jacks on the back of the US-144. The MON MIX dial will adjust what goes out through these jacks. If you move the dial all the way to the left, you will hear the input from the guitar directly from the US-144. If you move the dial all the way to the right, the signal goes through the US-144, into the PC via the USB connection, then back to the US-144 through the USB cable, and then out through the line out jacks. You may not hear anything when it is all the way to the right until you have Cubase open and configured properly. IMPORTANT NOTE: If you have MON MIX dial turned all the way to INPUT, you will not hear anything being output from your computer.
The LINE OUT dial adjusts the volume through the LINE OUT jacks. Make sure this isn't turned all the way down.
At this point, you should be able to turn the MON MIX dial all the way to INPUT and hear your guitar. It will probably only be coming out of the Right speaker, which is what it should be doing. Now turn the MON MIX dial back to somewhere in the middle so you can hear both the input from the guitar and your PC.
I downloaded and installed any updates that were available for Cubase LE 4 (I think all I needed was the 4.1.3 hotfix).
In Cubase goto Devices>Device Setup>VST Audio System and choose the US-122L /US-144 ASIO driver from the pull down menu. I'm not sure how important the "Relase Driver when Application is in Background" checkbox is, but mine is unchecked. If you click on the US-122L / US-144 section, you will see a button for the Control Panel. It will tell you what your driver and firmware are and what USB mode you are operationg in, etc. I didn't mess with any of these settings, but it is good to know how to get there. You should also see all your in's and outs. I have 2 analog in's and out's and 2 digital in's and out's. I am only using the analog in's and out's. Hit OK to close out this menu.
Now goto Devices>VST Connections and you should get a new window. There is an "Inputs" tab and an "Outputs" tab. Under Outputs, you should have a Bus for Stereo Out using the US-144 as your Audio Device and the US-144 Analog outs for the device ports. Make sure the "CLICK" colum is checked if you want to hear your Cubase metronome through your speakers. If you don't have a bus, add one and set it up as I have described.
Now goto the Inputs tab and add a mono input using the US-144 analog in R as the Device Port.
Now start a new project and add an Audio track using the Mono in and stereo output. Use the Edit Channel Setting button if you have to change your input and output.
Now with the MON MIX dial all the way to the right and with the Monitor button enabled on your audio track, you should be able to hear your guitar through Cubase.
Now if you turn on the Record Enable Button on your track and then press the Transport Record button, you should be able to record your guitar. Hit stop and then go to the beginning of the track and hit play. You should be able to hear what you just recorded. Don't forget that if the MON MIX dial is all the way to the left, you won't hear anything from your computer.
Well that is my Cubase LE / Tascam US-144 Getting started guide written by a newbie for newbies. May my pain and suffering alleviate some of yours. Good luck.
Posted on Jan 06, 2009
SOURCE: midi problem
Hi. I got an US-122L and certainly got the same problem, and it also seem to happen with the TuxGuitar. What I've seen is that the Tascam receive the data and then route it to the midi out port 'cause the led of it flashes, so I think we need to got a midi instrument to play the music. The only thing that make no sense is that I can stillplay midi files and hear them through the US-122L but not the Guitar Pro sound; I think the software sees a midi interface and sends data instead of sound. Does anybody know a way to change that in the program?
Posted on Feb 26, 2010
Faridbanga
  • 63 Answers
SOURCE: tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Posted on Apr 11, 2010
My tascam us-144 only plays in left ear, and I do not have cubase, need fix!
Hello you can download a manual and other stuff here:
http://tascam.com/product/us-144/downloads/
You need adobe reader to read the content.
Good luck
Dec 12, 2012 | Tascam US-144 Sound Card
Everytime I want to instal my sound cart the installation gets interrupted with problem 0x0006
this is link for Tascam.The US-144 has ben discontiued and replaced y us-144 MKIII. The general consensus that I see is that they are very hard to work with. You can type "tascam us-144" in your search box and read some of the reviews.
Mar 17, 2011 | Tascam US-144 Sound Card
I lost my tascam us-144 installation disc
Here is a site where you can down load driversand software:
Good luck.
Mar 03, 2011 | Computers & Internet
I get no response from my Tascam US-144 and windows 7.
Go to program,look for tascam folder and adjust channel 1&2 to analog.This should make your music program work fine.And then do research on both analog and digital recording.
-William Marcelin
Apr 09, 2010 | Tascam US-144 Sound Card
I have been given a 144mk2 but it has no driver disc can you tell me where I can download/purchase the driver. Thanks.Alex. Ps I live in the UK
Here is a link to the US-144 drivers:-
http://www.tascam.com/products/us-144;9,15,70,19.html
Apparently there have been problems with this device - it is recommneded to use the lastest firmware.
Nov 02, 2009 | Tascam US-144 Sound Card
I need the drivers download for the tascam us144 for windows vista
http://www.tascam.com/i-406-232-128-6-1DFAFF45.zip
This is a driver for Windows Vista/XP 32-bit system and I found it on this page:
That page includes manuals, firmware (the program embedded on the 144), etc.
Aug 13, 2008 | Computers & Internet
TASCAM US 144
Are these problems that have cropped upover time, or is this a new installation?
accordianman
Apr 03, 2008 | Tascam US-144 Sound Card
Tascam 144
Check pan control and then try another set of phones...accordianman
Feb 12, 2008 | Tascam US-144 Sound Card
Jan 15, 2008 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
263 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
