Question about Haier HPAC9M Air Conditioner
Doesn't blow very cold air - Haier HPAC9M Air Conditioner
  • Haier Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 21, 2010
2 Suggested Answers
  • 230 Answers
SOURCE: GE air condioner doesn;t blow cold air
That is definitely a problem. Make sure that all the related filters and coils are clean. If there is ice forming then wait until the ice thaws after checking the filters and then retry.
If this doesn't work you will need a contractor to properly diagnose the system and check for any recalls or manufacturer warranties.
Posted on Jun 23, 2008
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
Apr 19, 2012 | Dometic Rooftop RV Air Conditioner
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Blower on heat/a not working
So it works with a/c but doesn/t work with heat. Is that what your saying?
Or it blows cold air on heat selection?
If it blows but only blows cold air on heat selection
check out the following items:
temperature selector switch
blend door actuator and motor.
Here are a list of items to check out or have a shop inspect if it doesn't blow anything at all.
a) on/off switch
b) relay
c wiring
d) resistors
e) blower motor
May 11, 2010 | 2004 Chevrolet Colorado
Temperature gauge fluctuates and the heater blows cold air
Definitely check your fluid level in your radiator. Top it off all the way. I've seen that happen multiple times on cars that were low on anti-freeze. If that doesn't work try replacing your thermostat. It's cheap and the easiest place to start if topping off the fluid doesn't get you fixed up.
Oct 16, 2009 | 1997 Chevrolet Camaro
The air conditioning isn't blowing cold air anymore. It takes a while for it to get Cold, it blows cool air but not cold.
My name is Ron,and I have one solution,Sounds like you need some freon added,if that doesn`t fix ya ,the ac compressor could be weak,or blockage in ac system,or vent door not opening,or opening slowly,and not all the way...hope this helps,roniecon@gmail.com
Jul 19, 2009 | 1996 Ford Explorer
Heater blows out cold air half the time
the heater doesn,t work blows cold air
Nov 20, 2008 | 2001 Ford Taurus
Haier HPAC9M Air Conditioner Logo
397 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
