Vista really slow even after clean install with 6400 AMD 9800GX2 and 2GB ram and m2n32-SLI deluxe
  • dannyboy3213 Apr 21, 2008
    haya thanks for the reply yea i have done all sorts of things to solve this ill tell you what ive done so far
    1when i do clean reinstall she is fast then after that nvidia drivers then service pack 1 thats when she gos slow and i can see that the nforce raid drivers are changed and that if i turn file sharing off she goes alot faster the pc goes relly well on another mobo of myn but as soon as i use my good motherboard she goes to granny mode im thinking SP1 problem and as of right now i trying to run it without SP1 and see what happens so will tell in about an hour cheers
    President:
  • 1,996 Answers
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 17, 2009
    Genius:
  • 1,226 Answers
Vista is faster when it is clean install. the only reason when computer come to very slow when the hard drive is defective. or there is a hardware that defective also. please remove some hardware one by one and test. like CD?DVD ROM and others,
REfix also the memory and then obesrved the computer, if all the suspected hardware were remove and same performance maybe you need to replace the harddrive:
melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 21, 2008
  • Emelio Navaja
    Emelio Navaja Apr 21, 2008
    yea, thats correct. when installing SP1 can cause slow because thats run as another program.
    Its very good to install windows XP with builtin already the service pack 1."Windows XP service pack 1"
    After installing windows XP i would suggest you to install first the chipset of the motherboard, and then all the driver needed. hope this will resolve the issue.
    melnavz
  • Emelio Navaja
    I hope you will rate my solution good.
    melnavz
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Sounds like you built this puppy.
1) Does it use metal standoff's to hold the motherboard up off the Support Plate? (Standoff is metal, Spacer is plastic)
Do the standoff's match EVERY mounting hole in the motherboard?
To wit, there isn't a standoff sitting on the support plate, that doesn't match up to a mounting hole in the motherboard?
If there is a standoff in the wrong spot, it could be shorting against the exposed solder joints on the bottom of the motherboard.
2) is the 4-pin +12 volt power cable from the Power Supply plugged into the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ Two Yellow 12 Volt wires, two Black Ground wires ]
3) Thermal paste applied, and properly? AMD processors don't play when it comes to heat. If they reach the thermal limit, (Like any Processor), they turn off, BUT, an AMD will turn off in a heartbeat.
Heatsink sitting flat on the top of the Processor's case? I use a 'birds-eye' view with the mobo out, and look across the side. (Sides, ends)
4) Zalman fan doing it's thing? Spinning?
Spinning all the time, no intermediate spinning of spinning a few times, and stop?
Spinning at the proper RPM?
5) Patriot ram seated well? Locks are in tight?
Didn't get bumped when you were hooking up power cables?
Remove/re-seat. Only takes a few minutes, and will help you sleep better tonight.
(Both of those ram memory modules in the same channel?)
6) Power Supply known to be good?
What is with the 40GB Seagate harddrive? Typo, and meant 400GB?
Sli will not activate....... Vista 64 ultimate , 6 gigs of ram, 2 xfx 9400gt 1gig, amd phenom quad 2.5 , asus m2n sli deluxe
Hello raidon1449
Have you accessed BIOS(startup and start tapping F2) to see if SLI and not PCIexpress is selected?
The best thing that I can recommend with any SLI or Crossfire setup is to install the cards seperately at first to make sure they are working by themselves. Then install the cards in SLI or Crossfire configuration.
Jul 09, 2009 | Computers & Internet
ASUS M2N32 SLI Deluxe - Fans Come On But Board Doesn't Post
there should be a four pin connector from the psu to the mobo,if thats not it try removing memory sticks one at a time, just make sure you leave one in
Apr 09, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
M2n32-sli premium vista edition motherboard
I think you are mixing ram.... Use the same make and module for your ram... when you mix ram, the problem is other ram can be difernt Voltage. some 1.9V, 1.8V, 2.0V, 2.2V to operate. If you have 1.8V and 2.0V the computer won't boot. Hope this helps.
Dec 21, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
My m2n32-sli premium vista edition motherboard refuses to boot up when i put 6 gbs of memory. How do i solve this issue?
Hi iimarceloii, did you check the FAQ section on Asus web site?
Using Vista 32bit/64bit edition or win XP;
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=M2N32-SLI%20Premium%20VISTA%20Edition&os=24
Basically Asus wants you to use 2GB of memory until windows has been completely installed & completely updated before you can add more memory to the system.
Than you can increase your memory to 6BG. To see all the FAQ's from Asus, click on this link; http://support.asus.com/download/download.aspx?SLanguage=en-us
Type: M2N32-SLI into the search window & click the arrow button.
Good luck iimarceloii!
Merry xMiss
Mike
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Asus Premium Vista M2n32-Sli
Dear Riddler2002,
First thing u have to check the SMPS if it is not working properly then it will restart automatically not working properly it means that the SMPS not giving the excact power supply to mother board now the question is how can u check the SMPS working fine or not do one thing borrow a SMPS through u r friend connect that SMPS to u system if it working with u r friends SMPS then u have to change u r SMPS if still u r getting same problem then u have to check u r system RAM if RAM not work Properly then it will get this type of problem so Change the RAM and connect another RAM to u r system if the RAM is working fine then it will work properly.
Regards,
Bittu_8
Feb 13, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
