Question about kawasaki Full Suspension Mountain Bike Men
Jet ski want start in water? - kawasaki Full Suspension Mountain Bike Men
    President:
  • 1,978 Answers
Clean the carburetor you have moisture corrosion. Pay attention to cleaning the rubber tipped needle. Do not alter the little spring in any way.
Posted on Sep 03, 2010
How to fix slt 780 fading speedometer
Fading as in can no longer read the gauge or fading as in the needle drops as the jet ski runs across the water even though same speed is being maintained?
Jul 19, 2014 | Clymer Polaris Jet Ski & Water Vehicles...
Jet ski troubleshooting
what make of ski ?? does it get water in the engine all the time ? more info please ?
Feb 15, 2014 | WSM 1998-1999 Yamaha Gp 800 Cc Jet Ski...
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
What is the difference between a powerboat and a jet ski?
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Jan 17, 2013 | Boating
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
I have a 1994 Polaris jet ski slt 750 that will start up when it's out of the water but when I put it in the water it won't start. It just started doing this. I had the battery checked and was told it was...
You are deal with moisture corrosion in your carburetor. Take the carb off and clean it paying attention to the corrosion on the rubber tipped needle. Also open your electronics box and make sure that it is dry.
Aug 08, 2010 | Encore Software Kawasaki Jet Ski...
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
kawasaki Full Suspension Mountain Bike Men Logo
71 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
