Question about DeLonghi A120E Air Conditioner
My Delonghi A120LE Drips water not sure why - DeLonghi A120E Air Conditioner
  • 3 Answers
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Posted on Jul 26, 2010
  • johnhmai Sep 28, 2010
    This did the trick. I came to the same conclusion after opening up my a120le and troubleshooting it.
  • Amy Kyles
    Amy Kyles Jul 05, 2017
    Thanks :) this helped me too!
What I found after taking the panels off was water from the coils had collected on the right side of the pan leading to water spilling over so I made a wooden stand 6 inches tall,the leg of the stand I made a half inch taller so the collected water drained to the left and also aids in draining water from the unit.
Posted on Jul 28, 2010
After extensive leaks on my DeLonghi A120LE, I decided to place a large heavy duty tray beneath the entire unit. My hardwood floor has already been warped by leaks in the last few days. I have now enhanced this solution by placing a set of casters beneath the large tray. Another tray collects the water using capillary action. Photos can be seen here: http://picasaweb.google.com/Raymuser/DeLonghiA120LEPortableACLeak#
Best of luck!
Posted on Jul 17, 2010
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
How can I fix a very slow coffee cycle.
Maybe a very obvious question, but did you try descaling it?
Nov 15, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Why is my delonghi ec702 brewing slowly even after regular descaling? The water barely drips out even with no coffee in the filter.
I had same problem, now gone. Check your water Intake filter in the water reservoir. If it looks discolored, it may be clogged. I used a brush and plain water to clean it off, and now machine works like brand new!
Jul 28, 2014 | DeLonghi EC702
Tasciugo dehumidifer about 10 years old has started to leak. I have cleaned filter and spout water drips from is there anything else I should do. ?
Drips from where?
Find the source of the drip and seal it with rubber or waterproof tape.
If there is no pressure at the leak, this should cure it.
If you have trouble locating the leak, dry off everything and operate the
dehumidifier while you watch for the appearance of the moisture. Where
it first appears is probably the leaking location.
Aug 29, 2011 | DeLonghi Dehumidifiers
I own a DeLonghi Penguino A120LE, I have cleaned all filters and there is no service codes coming up but it does not cool any air? is there a way to re-charge the coolant?
Yes, it can be recharged with refrigerant. But, it's best left to the pros. But, before saying that's exactly what it needs. I'd like to know if the compressor is in fact turning ON or is it just the fan running?
Aug 27, 2011 | DeLonghi Pinguino PACL90 Portable Air...
How to remove panels from air conditioner - Delonghi PAC A120LE
Are you referring to the from panel of the air conditioner?
Please look for screws or hinges on the side of the fron panel and once you've found them remove the screws or gently take off the the cover from the hinge. (you may have to use a flat head screw to remove the face cover if it's locked by a clip).
Hope this helps!
Jul 03, 2011 | Heating & Cooling
DeLonghi A120 12,000 btu ar conditioner Leaks
Jul 10, 2010 | DeLonghi A120E Air Conditioner
I have a Delonghi PAC A120LE air conditioner that leaks water. How do I stop or divert outside? I noticed there is a drain on the back - should I put a hose on that?
Aug 19, 2009 | Heating & Cooling
DeLonghi A120E Air Conditioner Logo
3,436 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
