Question about HP Computers & Internet
,,my problem is to how reset bios password for hp pavillion n5150, i cant see cmos battery in motherboard pls help to my problem,. how can i reset it,. tnx
  • 251 Answers
Hi ,
remove the '' pwd'' jumper from the motherboard then reboot the machine .
Posted on Jul 16, 2010
Hey I am trying to log on to my laptop and for some reason FORGOT my password HELP PLS
When you boot up to the log in screen type in administrator as user to log in if you cant log in
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
what operating system and type of computer???
hope this helps you
Aug 27, 2011 | Toshiba Computers & Internet
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
Jul 25, 2011 | HEWLETT-PACKARD 574508-001 - Original HP...
Intel Hp c.p.u. asking password .we do not use password to open our p.c.then why our p.c. ask for password ?
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 03, 2011 | HP Compaq Motherboard
I FORGET MY LAPTOP BIOS PASSWORD WHAT CAN I DO I HAVE HP COMPAQ 610
i,
To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Dec 27, 2010 | HP Compaq Motherboard
Remove password on my hp n5150
This is the BIOS password. BIOS password is stored in the CMOS/ RTC battery of the notebook. So if you would remove it, reboot the notebook and then again reseat it. BIOS passowrd will get removed.
Check this link and download the manual to get the procedure for RTC battery removal.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=57784&lc=en&cc=us&dlc=en&lang=en&cc=us
If your laptop is in warranty you can call up HP and they fix it or give you the procedure to remove the password.
Dreamkam
May 28, 2010 | HP Pavilion N5150 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How can I reset a bios password on a Pavilion laptop
You will need to unlplug the motherboard battery for five minutes or if there is a jumper switch set it to clear the BIOS options.
After five minutes or so you should move the jumper or plug the battery back in.
Your bios password will now have reset.
If his has helped you then please rate me!
Aug 26, 2009 | HP Computers & Internet
Forgot my password for my Presario SR122NX
if u forget BIOS password so first remove power cable and moniter cable and than remove cmos battery on motherboard for 2-3 min. after that put cmos battery back in same possition and start ur pc...and set bios time and date..
If U forget windows password so pls tell me which windows u use...
than only i will give right ans of ur qus.
if work RATE me if not reply me
thanks
bye
Mar 20, 2009 | HP Compaq Presario SR1222NX (PN234AA) PC...
Administrator Password for BIOS lost
Nope, if you do not have the bios password, the only way to reset it is by accessing the motherboard, removing case and keyboard, and either removing Cmos coin shaped battery for one second, or bridgeing the Cmos reset jumper (that interrupts contact to battery, same as removing battery).
Oct 09, 2008 | HP Compaq nx6110 Notebook
HP laptop 9000 need help installing webcam
Feb 22, 2008 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
144 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
