Question about X2Gen MG19MY 19" LCD Monitor
Have power getting no picture -- worked 2 hours prior no events
  • 732 Answers
Sepati, You forgot to tell us how old your monitor is! Could be that the internal power supply (ac to dc) is in shutdown mode because it has detected a fault condition with itself (smps) or the cold-cathode-fluorescent-lamp "electronic ballast circuit" called an "inverter" which converts 12vdc to 500 to 1000vac to light-up the lamps so you can see what is on the lcd panel (screen) .. Some can be repaired for $5 in parts on a DIY basis. Some due to age alone are not worth the $50 or higher cost of contracting out the required work. Here are two things you as an owner/user of ccfl back-lit lcd monitor should do when confronted with the "black screen of death". 1. learn how to do the "flashlight test" to evaluate (gross) the state of the units SMPS, and what it means. 2. then go to YOUTUBE and search and view some useful video clips that will show you what some owners and technicians have done to make these things work for another 1 to 4 years. Do some further reading in my and "budmrtn" "buddymc" fiya profiles for more info on DIY fixes. If this was of some help, then leave reply and rate this response on fixya.
12fixlouie
Posted on Jul 16, 2010
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Tip
Lamp Reset Procedures for Toshiba TVs.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire. At the very least it will cost you more to repair.
The manufacturers goal for having a lamp timer is to get the customer to change the lamp prior to a catastrophic event happening. Most lamps only last for about 3 years and that equates to 6000 to 8000 hours when watched for more than 8 hours per day.
To reset first make sure the TV is unplugged from the electrical outlet.
1) Turn the main power switch to the "ON" position.
2) Press and hold the "On/Standby", "Menu" and "Input" buttons at the same time. The buttons are on the projection TV. Though the same buttons are found on the remote control, the reset only works with the buttons on the TV.
3) Plug the power cord back into the outlet while holding the buttons in Step 2.
4) The lamp timer will reset when the projector receives power.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours or three years which ever comes first.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Jan 29, 2011 | Televison & Video
Batteries do not last anytime, after taking a few pictures get message "low battery".
The camera is running in reserve battery power. perform a full power charge usually expected to last an extire ccouple hours to makes camera useable once more. Prior to power charging battery on camera, power off the camera completely and allow to achieve full currrent replenishment.
Feb 03, 2011 | Mustek MDC 832Z Digital Camera
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
No picture seen or recorded - only audio
I had a similar problem with my Sony 14E in that it would not record at all - sound or pictures. Prior to that I had the lines indicating head cleaning necessary. I did this, and still nothing. I then did the following which you might try.
1. Clean the heads (I did it about 3 times in the space of a couple of hours).
2. Leave the camera tape section open (with or without the tape in) for a couple of hours and the camera in a WARM PLACE. I had condensation message prior to my problems too.
3. Put in a recorded tape and attempt to view it. Immediately I had the "dirty" lines for a few seconds then it played the recording.
AT THAT STAGE I TRIED TO RECORD - NOTHING.
Repeat Steps 1 - 3 because this seems to be about dirt and cold.
4. When step 3 is reached again! try to record. Eventually this worked for me.
I hope this helps and works for you.
Jan 03, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
Power window failure on drivers side
Sometrimes the wires between the door and the body break from opening and closing the door, check your window motor for paower with a test light, if no power, you have a broken wire, between the door and body
Dec 22, 2008 | 1999 Saturn SL
X2Gen MG19MY 19" LCD Monitor Logo
82 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
