Sennheiser wireless headphones model hdr 126 stopped working only static heard. Red light indicating charging only green power/on light won't come on.
mikeymiddles
  • 58 Answers
SOURCE: how do you connect wireless headphones to back of receiver?
use the front pre-outs located immediately over the red "right" A&B speaker connectors in the rear of this unit. connect with a high quality stereo  gold plated rca cable.
Posted on Jan 08, 2009
cardmechanic
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
cardmechanic
  • 9 Answers
SOURCE: Bad battery
Battery Part Number: BA 151
Sennheiser Link:
  • 155 Answers
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Posted on Apr 24, 2009
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Why don't either the charging or on/off lights come on when my transmitter is plugged in?
Bad connections. Plug in and withdraw multiple times, It may serve to "clean" and polish the contacts. Hope it works.
Mar 27, 2015 | Sennheiser HDR 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
How do I charge batteries?
The headphones will automatically charge wirelessly when placed in the cradle that should have come with the package. To make sure the headphones are placed correctly, a red light should illuminate letting you know they are being charged and are properly placed.
May 03, 2011 | Sennheiser HDR 120 Consumer Headphones
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Jan 26, 2009 | Sennheiser RS 120 Consumer Headphones
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Have not used them for a while
These systems have some signal detection, so needs an input to fire it all up. That is the same for the greenlight, when initially switched on for my HDR 120.
Dec 26, 2007 | Sennheiser HDR 130 Consumer Headphones
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
155 people viewed this question
 Grubhead
Grubhead
