Question about Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
First the display is showing check SP wires, I've checked the speaker connections and it seems to be fine then I tried to power it on again it will only stay on for one or two seconds the it will shut itself down.
  • 2 more comments
  • benbury Jul 11, 2008
    have the same check speakers mess. and it turns off. It does seem to work fine when the volume is in the - db range,but when you turn it to +db it immediately turns off please help!! Started appox 2 mons after I bought this.
  • shamilleon Aug 13, 2008
    It's a piece of ****
  • Tackaberry Dec 07, 2008
    I am trying to use a Mac Mini as an audio input and I can only get sound for a few seconds before the amp trips and shuts down.  I have tried the CD input and the MD/CD-R input.  I am using a cable which is stereo minijack on the computer and two RCA (white/red) jacks on the other end.
    Please help!
  • Anonymous Feb 26, 2009
    I have the same problem with my Yamaha amp. The problem seems to be intermittent, though!
    At first I thought that it was the surge-protection plug that I was using because when I took it to the dealership, the salesman connected it up and it worked perfectly.
    When I took it back home, the same error message appeared without any speaker wires being connected.
    When I get the chance, I'm gonna try and repair it myself.
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Posted on Mar 06, 2009
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Unit turns itself off after diplaying code "check SP wire"
My guess, guess, check CLOSELY the SPeaker wires - "Check SP wire" make sure all of the bare portion of the wire is into the terminal. No bare wire touching another bare wire both at the receiver and at the speakers. Also, if the wiring is not continuous, check all connections of speaker wire. Disconnect all but one, play it like that. If no problem, label that as good, disconnect another for several days, when one shuts Rec. off, check wires closely for that speaker.
Jan 23, 2009 | Yamaha HTR-5650 Receiver
My yamaha receiver shuts down when I turn it up.
If you have bare wire going into the receiver's output terminals, make sure a strand or two of wire is not touching the other terminal. That can short out the outputs, especially when you turn up the volume, which increases the voltage present at those terminals. That would cause the receiver to shut down as a saftey precaution.
Dec 13, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Feb 21, 2008 | Yamaha HTR-5940 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
Yamaha HTR-5940 Receiver Logo
221 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
