Question about Toshiba TZ50V51 50" Rear Projection Television
Fuse blows i put a new fuse in location f 889, its a 3.15 fuse and it keeps blowing. any ideas? thanks
  • Toshiba Master
  • 8,617 Answers
Check for shorted horizontal output or one of the low voltage regulators being shorted. Must remove from circuit to check for shorts
Posted on May 11, 2008
Why does the #32 fuse on my 2005 rendezvous keep blowing
You have a short some where in the wire from the fuse box
Apr 29, 2016 | 2005 Buick Rendezvous
I have a 2003 mitsubishi lancer. Everytime I try to turn my key from the ignition to start my car my fuse 4 (40A) blows up I replaced it twice but the new fuse just keeps blowing up:/ what's going on?...
There is a major electrical fault that keeps blowing the fuse. The fuse protects that part of the electrical circuit, 40 amps is heavy electrical circuit, it it wasn't protected by a fuse it car could catch on fire.
You need to get an auto electrician or your Mitsubishi service center to locate the fault and repair.
If you had a wiring diagram for your car then you can trace the wiring from the 40A fuse to the various components to locate the wiring fault or component fault.
Dec 30, 2012 | Cars & Trucks
My fuel pump fuse keeps blowing
Can not guess why
Has to be diagnosed by a shop
with a data base, so they have access
to wiring diagrams,just like all vehicle repairs
I would think that the fuel pump is worn out
Oct 03, 2012 | 1998 Holden VT Commodore
Ignition Fuse keeps blowing
Hi Jeff , in what fuse box is this 10 amp ign. fuse located ? I am looking at a power distribution diagram and i see a IGN 3 10amp fuse located in the I/P fuse box ! Is this the fuse that blows ? I see where you replaced the 10 amp with a 30amp . That is never a good idea , you don't want to make your problems worst . Melt wiring harness , could start a fire . Do you know how to do electrical trouble shooting ? How to use a wiring diagram , power distribuition diagram ? That fuse is hot in the run , powers the rear Heat / A/C , automatic level relay, ESC - electronic suspension control module , rear wheel steering control module , Plus someother thing's depending which vehicle , Y91 - ULT . Your Taho doesn't have all this options . http://www.bbbind.com/free_tsb.html find the thing's that fuse powers , disconnect them one at a time till the problem goes away .
Apr 08, 2017 | Cars & Trucks
Radio Fuse blows
any time a battery is hooked up backwards anything that contains diodes will have to be replaced.unplug the radio and see if you can put the fuse in without it blowing.when you get the vehicle going have the alternator tested,it also has diode in it.good luck.
Sep 30, 2009 | 2000 Nissan Xterra
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
AMp keeps blowing fuses
http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Hi You can refer to my detailed solution above...if you still have issues please feel free to contact.
Thanks
Feb 15, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Toshiba TZ50V51 50" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
