Question about Sony Cyber-shot DSC-W120 Digital Camera
My camera won't turn on, and if it does its only for brief periods of time
  • 51 Answers
Please replace standard alkalines with rechargeable NiMH batteries Sony or Varta 2700 Ni-MH!
That's was working for me!
Posted on Jul 16, 2010
Turn battery temperature high
hello,you have the most popular problem,that every 1 meets,regarding most modern consumer good's,relating with battery's. DO NOT charge up your battery,too often,as you unwittingly are OVERCHARGING the battery,as temperature is directly related to cells that are taking in far too much current,use your camera,till it dies(total loss of power) then only charge for a brief period,then leave camera for a while,before re-using. vary the state of charge/in relationship to usage,and do only charge battery infrequently. hope that helps, cheers.
Jun 26, 2013 | Nikon Coolpix S205 Digital Camera Red
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Hi! I have a Nikon Coolpix. I haven't used it in a while. I charged it over night but it won't turn on.
Your batery is dead they don't like long period of staying discharging (If you 100% shure that your Nikon is working) The time of charge dosen't matter.
Jun 02, 2011 | Nikon Coolpix S210 Digital Camera
The cradle is not working
The A340 use a small battery. My advise is change it for an new one, they are very cheap and you can buy it in every good photo store
regards,
Rob
Apr 11, 2009 | Fuji FinePix A340 Digital Camera
18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Mar 25, 2009 | Garden
I was taking a picture one day and all of a sudden my camera turned off. But when it turned off the camera lense stayed out. Now I charged the battery and it still won't turn on.
For a temporary fix, once the lens is fully extended, turn the power on (the light should flash for a very brief period), and within that period, repetedly smack the top of the lens and it will retract. Ps. It can take more abuse than you may think.
Also, this is simply temporary. Sometimes it will work for a day, and sometimes a month. And even soimetimes it won't work. But it's worth a shot if you have a perfect photo-op.
Oct 29, 2008 | Cameras
Lock code
HTC X7500/7501-(ATHENA/ADVANTAGE/Dopod U1000/T.Mobile AMEO)
Slide the Volume slider down and at the same time, use the stylus to press the RESET button at the back of your
device. After a brief period of time, two choices will appear on-screen. Press the CENTER OK button to perform the
hard reset. (Otherwise, if any, press the CAMERA button to exit.)
or try with this link...
http://www.efsoft.it/resetdev.htm
Jun 09, 2008 | HTC Advantage X7500 Smartphone
I have a premier DS 6065, and the shutter is supposed to turn the camera on and off, unfortunately it isn't working, it has done for brief periods but once turned off by taking the batteries out, the...
Take the camera apart and put it back together again, making sure that the bit of the shutter that pushes the inner switch is aligned to the inner switch. The inner switch, when pushed and held when the camera is dismantled, will turn the camera on - it's on the front at the bottom. It's fairly straightforward to work out how it's supposed to work - you just need quite a fine screwdriver.
Apr 29, 2008 | Cameras
Power save feature
ارغب في برنامج لتعريف كاميرا نوع كانون mv650i
Apr 21, 2008 | Canon MV650i Mini DV Digital Camcorder
Sony Cyber-shot DSC-W120 Digital Camera Logo
144 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
