Question about HP Computers & Internet
Laptop display too dim
Display too dim- other lights are all on on the laptop,.
  • 69 Answers
Generally on the hp press and hold the fn key and use the up and down arrow keys to adjust the screen
Posted on Jul 17, 2010
Lenovo w500 Laptop Dispya invisible
Hello ...
try to open on the back panel of your laptop and clean the memory card using eraser.. It mean if you open your laptop or on. there is no display will appear...
But if you on your laptop then after it. It will continue to loading to a windows.. but the desktop will display black or dim
press Fn + (F1 to F12) look the logo is lamp or bulb ust like that. then it will increase the brightness of your screen.
Mar 07, 2014 | Lenovo ThinkPad W500 Notebook
I have sony vaio vpceh25fd ,my screen was broken but was still working before i replaced it to a new one,after replasing the screen i am having a very dim display.even i tried the previous (broken lcd) its...
The dim display could be caused by a faulty inverter. The inverter supplies high voltage to the CCFL lamp that provides the back light to the LCD screen.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 14, 2013 | Computers & Internet
Real dim display on boot
If you boot to Safe Mode is there any difference? If you connect a External Monitor,, any difference? What is the Laptop Make and Model? The OS?
Mar 05, 2013 | Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
My laptop IBM R50e, i boot and have a display but its dark/dim.. when i click FN+F7, it dsplay for 1 second and go dim again
one possible cause would be the inverter. Much better to send it to the technical person or shop for deeper diagnosed on the laptop. Just a thought hope it helps thanks.
Sep 22, 2011 | IBM ThinkPad R50e Notebook
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
My laptop l2000 screen is dim but i can see
the display backlight is burned out that is why its dark. it can be fixed but, the whole display has to be replaced..
Nov 13, 2009 | Computers & Internet
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
