Question about Zhone (6218-I2-200) Router
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
    Guru:
  • 825 Answers
Try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Posted on Jul 16, 2010
Need to open port on my 6218-12-200-0CC router for xbox live but dont know how
2 ways you can do this. <br /> 1. Connect to your router 192.168.1.1. Go to advance setup, NAT settings, then virtual servers. Click ADD, you will be at a setup screen now, click Select Service and choose xbox live. Then type in your ip address just below (192.168.1.1) and click save/apply, thats it.<br /> 2. Go to this site, <a href="http://www.portforward.com">www.portforward.com</a>, go through the motions and selct your zhone 6218 modem. Follow the directions they have listed.
Aug 08, 2010 | Zhone (6218-I2-200) Router
Unable to get log in page for modem
try doing a Google search USUALLY the address is 192.168.1.1 if your running xp or higher look for the command prompt icon it is in the start menu under acessorys the type ipconfig it should give you a number for your gateway or call up the manufatures tech support
Jun 29, 2010 | Zhone (6218-I2-200) Router
Need login and password for a Zhone router/modem Model #:6218-I2-200-0CC.
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
Dec 20, 2009 | Zhone (6218-I2-200) Router
How to turn zhone 6218-i2 router to wireless, now am using cable?
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
Zhone 6218 I2 User Manual
Nov 21, 2017 | Zhone (6218-I2-200) Router
Zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 06, 2008 | Zhone (6218-I2-200) Router
Username & password
yes you can change the ssid
do to device then select adminstrator then change it username and password
Jul 15, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
NAT? Where?!
Perhaps you are using a different firmware than the one they are using in the guide. If they are using an older one then you may just need to figure it out. Look through your router's settings again for anything that mentions NAT, Port Forwarding, or Virtual Server. Then just pick the port (or ports) that you want to forward and which machine to forward them to.
One last thing that may be causing your issue is that you are not connecting to your router. Does the configuration page that you visit display your routers make or model? If you have a modem and a router, then it's possible you are actually connecting to your modem instead.
May 13, 2008 | Zhone (6218-I2-200) Router
Zhone (6218-I2-200) Router Logo
1,362 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Awesome12
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
