Question about GE (PSS26MSRSS) Side by Side Refrigerator
Door flap and latch to ice maker and water dispenser damaged after using a hair dryer to melt ice in water dispenser. Need a replacement flaP
    President:
  • 1,891 Answers
The parts you need can be found a www.apdepot.com part # 32 is door but latch / is ?? but in the diag you will be able to see what you need . hope this helps mm. . tip after reassemble try using food grade silcone on moving parts and shute this prevents freeze up .. mm
Posted on Jul 16, 2010
My ice maker is making ice, but it won't come out of the door. It gets stuck outside of the icemaker in the door. There is a flap that doesn't seem to be opening.
The units I have seen which have a flap, if water gets in from some drippage, it can freeze and make things get stuck. You might try some hot water on a small towel against the outside of the flap to see if that would melt any ice accumulation, or if you put a small pan under the flap hole on the outside to catch runoff and dribble a bit of hot water from the inside hole down spout to melt any ice that might free it up if that is causing it to stick.
You also might be able to fish out the ice from the inside and give flap a push to open it, or use a plastic spoon or spatula to push it through. While you might be tempted to melt the ice with a hair dryer, don't do that. It could be very dangerous if water suddenly spewed out and got into the heating element or motor and cause a fire or electric shock. Stick to not water and plastic to try and push it from the inside outward. Usually the mechanism to grind the ice is up above inside the freezer, not in the hole in the door.
If the door got stuck because its hinges came loose broke you might have to call a service center to come and replace it if you are unable to yourself.
Be careful and don't try anything if you are unsure of yourself.
Jun 17, 2015 | Samsung RSG257AARS (241 cu ft) Side by...
Why won't my ice maker work
Hello Cynthia! Most likely the little "flap" inside the door of the dispenser is not closing all the way. My advice is to take all your ice out of the inside of the freezer. Clean and dry out that area as good as you can. Take your hand, and from the bottom, reach up and feel the flap that should close all the way when ice or water is dispensed. Take warm water, pour it from the top, you won't need much, and dry off the little flap as good as can be.
Now, press the ice button, and when you let go, you should hear a clunk or deep sounding slap, that is from the flap closing properly. Same goes for the water. However some manufacturers don't open the flap for water. From this point forward, assuming you heard the flap close, be sure it makes that same noise every single time you use the ice dispenser, or the water dispenser, and your problem should be solved.
May 07, 2014 | Refrigerators
Ice door flap will not close
I had a similar problem once. i opened the door and used a hair dryer blowing into the dispensing area of the door. There was a ice build up that was not visible with a quick look. It takes a while so be patient when thawing and be sure not to use too high of setting so you dont deform any of the plastic parts.
Mar 17, 2014 | GE Profile PSS26NGS Side by Side...
The flap on the ice maker dispenser will not close.
Problem with these flaps are that they have plastic hinge which work great for sometime when they are new and have shiny inner surface but with use they develop minor scratches which cause resistance and hence partial closing. Either get the flap replaced or apply Vaseline jelly in the moving part of the hinge.
Apr 23, 2013 | Refrigerators
The ice dispenser stopped working ie it is dead when I press the flap to release the ice on the door
Are you check for some clogged water tube? Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
Additionally, use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Keep us updated.
Apr 20, 2011 | Refrigerators
My ice maker keeps freezing up and then it won't make ice cubes, water comes out, but no ice. We have taken a hair dryer and melted the ice but it came back. Why does it keep freezing up? It is a side by...
If your talking about the ice dispenser freezing up, check that the doop flap is closing properly. Sometimes a plastic eyelet will break and the flap will sit ackward. They make a kit to fix that even though they say you have to buy the whole door.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 28, 2010 | KitchenAid Refrigerators
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
