Question about Microsoft Windows XP Home Edition for PC
Lack of drive letters on my hdd.
I lack of drive letters on my hdd connected to other hdds with seevral partitions on each. What to do ?
* Please don't tell me I should get rid of at least one drive. I know it.
  • 22 Answers
Letters are limited but you can always use the letter for other drive without removing/disabling/getting rid of other disks. You can manage your disks by accessing the disk management utility. Right-click My Computer and click Manage (Disk Management) or open up Run dialog box (START menu->Run) and type in "diskmgmt.msc"
Next you can remove the drive letter from the drive which you are not using at currently by right clicking the partition and click on "Change Drive Letter and Paths" and click remove. Finally assign the letter to the desired disk/partition. It will appear on My Computer now.
Posted on Jul 17, 2010
HDD is being shown as unallocated. But it has data.so without formatting how can it will be allocated .
format the hard drive any way as it has to be in a particular format for the system
Nov 30, 2015 | Computers & Internet
Why won't the hard drive partition?
If the hdd is locked there can be a few reasons. The first that comes to my mind is, hdd key set in the BIOS or there are no letters assigned to the partitions. I use Disc Director to set up and/or repair hdds. It is an excellent programme and fairly inexpensive.
Jul 13, 2015 | Gateway Computers & Internet
Hi , seagate 1tb Expansion portable drive S/H: 2GHY01LD error in page operation plz help
Go to Start, right-click on My Computer icon and select Manage
When you go to manage, select Disk Management.
Click on Disk Management and you will notice all the disks (HDDs and any removable devices on your right column.
Click on the Seagate 1tb HDD,
(1) Note the file system
(2) Note the Status of the drive
(3) Note Fault Tolerance
(4) Then Notice the HDD if it is Basic or Dynamic
If the HDD is Basic, right click on it and create a partition.
Then move some of the Data on to the new partition to free up the old partition. Restart the computer and abserve the results...
That usually happens when the Hard Disk driver is running out of space or you have less RAM..
Aug 23, 2011 | Seagate 1TB 7200RPM 64MB CACHE...
In a Sony vaio the Fujitsu hdd reports an error and is unable to boot. When I hook the hdd up to a different system the files are accessible and usable. (ex. You can play music that's on it). How can I...
When you connect the Fujitsu to the Sony laptop. use disk management utility to see how the how the sony is characterizing the Fujitsu. If you can access the files on the Fujitsu from another computer, the Fujitsu is not faulty. Your connection with the Sony is the problem. Disk management utility instructions are listed below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
I hope that this information is helpful, if so, please rememeber to leave positive feedback.
Thank You,
Brian
Feb 13, 2011 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
Could someone help with the following: I am trying to replace the hard drive in a dimension 9150 and also add a second (storage) hard drive. sata drives I have connected 1 drive and installed XP from...
when installing XP to a blank HDD, that has no existing partition, If windows detects other drives (another HDD that has a partition, USB Thumbdrive, zip drive ot media card reader (I suspect your system has a 4 in one card reader) then XP install will see those drives and assign them drive letters and then assign the new partition created C: To avoid this, the simplest step is after creating the new partition on the new hdd in the XP install process, reboot the system and start the XP install again, this time it will see an existing partition on the new HDD and assign it drive letter C:
If you have already installed XP., I have found no SUCCESSFUL way to change the drive letter of the boot drive other than re-installing Windows.
Nov 26, 2010 | Dell Computers & Internet
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
How can i make my wd 160 gb 4 partions
well tbh it shouldnt really metter what operating system you are on, coz most of them are almost the same and they all do the same job how ever if you have ever installed any hdd of any kind then ul know that most hdds are partitioned. firstly you need to plug in your hdd and the restart your computer and put in the xp or vista operating system and boot from disk when it says press any key to boot press any key and it will take you throught the steps on how to format or make another partition and you will have a set of hdds to chose from, one being your C drive and the other being your exturnal drive. when u install a operating system it will give you the choice if you want to make another partition and then you just choose the size that you want it to be note that the size will come up as KB and not MB so it will be something like 160000 and then you wanna make 4 partitons so say you want 40GB for each one you should look at taken it down to 120000 and then 80000 and then 400000 you can do this as many times as you like but if this seems to hard or complex then there is another way im not 100% sure if its free but its paragon partition manager witch is a program that you just install and start it up and with your hdd pluged in it will show you all the hdds on your computer and you just select the hdd you want to partiton and then chose the size of the partition but yet again you can you can do this as many times as you want. if you are still having problems just send me a email and il get back to you. my addy is itsmrjt@hotmail.com
Nov 15, 2008 | Western Digital Passport WDXML800UE...
PS2 HDD Partition Error
A Partition error is the amount of segments that the hard-drive is split into.
For example we have 1 hard-drive Named C:/ Which Is 20 gigabytes. Then we decide that we want to use A Quarter of that drive, solely for saving games On. So 5 gigabytes Will Now Be allocated For Game-saves, This Will be known as Partition 2 Or D:/ So we now have 2 Partitions 1 is C:/ And 1 Is D:/ Partition C:/ is Currently 15 Gigabytes, And Partition D:/ is 5 Gigabytes.
Making a total Of 20 Gigabytes. So if your getting a partition error, it,s either because the game your attempting to transfer Is larger than the Partition, thats trying to receive it. You may be sending 4 gig to a 3.5 gig partition. Or your attempting to send it to a partition that is incorrect or inadequately lettered/numbered.
I hope this enables you to understand, the basics of Partitions on drives.
Mike @ Compurepair.
Mar 04, 2008 | Sony PlayStation 2 (PS2) Console
Not able to load any os
Here's a fdisk utility for you to use: http://www.shareup.com/Super_Fdisk-download-18631.html That will help partition and activate drives. If you don't know how to partition a drive, then this link will help explain, in tech detail, what you are doing: http://support.microsoft.com/kb/q221829/ If you want more of a layman's explanation, then goto this link: http://members.aol.com/_ht_a/weendoggy/index.htm As the person there went into detail as to what you are doing from what I think is a not-as-technical explanation as most other sites. Fdisk wipes your hard drive clear of anything when you run it, it then partitions the drives and activates the partitions so that a operating system can be installed on it. With your RAM, why did you even try to install Vista? Vista needs at least 1G of RAM for optimal performance, not to mention a good graphics card, and just overall new hardware.
Apr 06, 2007 | Western Digital Caviar WD400BB 40 GB Hard...
Microsoft Windows XP Home Edition for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
