I have an lg RH397D dvd recorder - the lcd just says Hello over and over and will not turn on.
You need to replace faulty cheap capacitors on the power supply board (one or two will be bulging on the top, with or without a brown exudate; see picture). This costs only a couple of dollars, or you can replace the power supply board for about $50.
Posted on Jan 09, 2011
  • 1 more comment
  • R.Stewart Aug 16, 2012
    Where can you buy the power supply boards, don't think I'd be too good at soldering. Cheers
  • Don Batten May 31, 2014
    Further experience revealed that this unit from LG has a design fault: there is not sufficient cooling for the power supply board. The heat cooks any brand/quality of electrolytic capacitors (the ones with the bulging tops in the previous picture). I constructed an aeration 'hat' of aluminum sheet above the damaged capacitors and have had no more problems. Below the hat is a hole in the original case to let the hot air out. The hat is 80 x 80 mm.
    One source of the power supply boards is:http://spares.bigwarehouse.com.au/produc... (I'm sure there would be suppliers in other countries). No soldering or special tools are required.
Can't play USB MP4 on LG RH397D
The LG RH397D only supports MP3/WMA/JPEG/DivX image and audio files from a USB drive. There is no firmware update that changes the supported file types. You will need to convert the MP4 to a supported format. The manual for the RH397D is available from LG: http://www.lg.com/au/support-product/lg-RH397D# /
I wish that I had better news for you.
Aug 06, 2012 | LG RH397H DVD Recorder
Hello, I have purchased an LG RH397D DVD Recorder in Brisbane Australia. Eveything works well except that I cannot receive channel 73 (mate) and 90 (Go). I can press guide and the recorder will tell me...
its simple ,HD stands for "high definition" and either your TV or DVD player cant do HD ,these channels will be only screened in HD ,this is why you cant watch them ,you will need to update one or both of them .THANKS for using FixYa
Feb 10, 2011 | LG Televison & Video
Our LG RH397d/rh399d DVD / Hard drive recoreder will only turn on and display the Hallo message, and you can hear a clicking sound from in side. I have remove the power cord no change .
Your DVD drive is having a problem. When this recorder starts, it checks the DVD drive for correctness. If incase your DVD drive is has problem in the ejecting mechanism then this will prevent your HDD from working correctly. Take the player to service center and fix the drive
Dec 28, 2010 | LG RH177 DVD Recorder/HDD Recorder
Cannot playback dvd-r on lg rh397d after recording from hdd. message is 'cannot playback due to navigation error' please help
When you burn a DVD, it is ONLY playable in the RH397D.
Buggy menus - and no way to flash the firmware.
Terribly designed remote.
HDD never seems to spin down, no matter how long it sits.
Doesn't play XVid.
I was a bit disappointed with this product. It does do, what is listed on the box, and one can't be too disappointed with that.
Sep 29, 2009 | Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Apr 06, 2009 | LG Televison & Video
Recording stops when i turn off the tv
Maybe setting for hdmi on dvd player is set to synchronize with tv, check manual to disable.
Mar 25, 2009 | Televison & Video
Televison & Video Logo
1,040 people viewed this question
Top Televison & Video Experts
