Question about Frigidaire Kitchen Ranges
Hi, Frigidaire range model# CFEF372CS2, the glass top has had an impact on the one burner, cracking it. Is it ok to use the other burners until it is repaired and is this a slide off top with the two screws mounted in the front? If not how do I remove it? Thanks for your help!
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Posted on Mar 03, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
How do I fix my left rear burner that has stopped working?
First of all, you need to test the wiring to that burner. If there is no electricity, then you need to replace the plug in. You can get them at an Appliance parts store. If there is electricity, then all you need to do is get a new burner at Lowes or Home Depot. Sometimes the burner gets a tiny crack in the burner that breaks the continuity.
Sep 01, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
I have a Frigidaire gas stovetop range that smells of gas only when the power plus burner is lit
I hope you haven't cracked the tubing to the burner. If the stove is a sealed burner model it could be that when you tried to open the top you could have cracked the tubing to the burner. I had this happen to a client just a few weeks ago. The damage was so bad they had to buy a new stove. You may be able to replace just the offending burner tube.
Mar 16, 2014 | Frigidaire Ovens
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Butter knife chipped burner - Amana black glass cook top
if it didnt crack or chip os not a hole it can be safe to use
Nov 08, 2017 | Amana AER5844VAS Stainless Steel Electric...
I have recently cracked the glass stove top, if I continue to use it will I sustain more damage and how much will it cost to replace it? We have a Bosch 30x24 glass smooth top with four burners electric....
hi gud day,much better to replae the new one compare to buy the glass top only coz the price of the glass is expensive or little diif for the new one.or if the broken glass is not appected to other burner its ok to use the other burner untill to u want to use.tnx
Feb 01, 2009 | Cooktops
Kitchen Ranges Logo
215 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
