Question about Polaris 380: Polaris Booster Pump
I need to know how to put on new belts on a Polaris 380 pool sweep
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
How to fix sideways Polaris pool sweep?
check ballast ball on top if water inside replace
May 13, 2014 | Polaris 380 In Ground Pool Cleaner
How many jets does the 380 have that may need to be cleaned, I see 3
It sounds like you have a clogged drive turban jet or an internal hose has popped loose. I normally tell people to double check the backup valve to verify that it has been installed the right way (widest part toward the wall,)
There is a total of 6 jets, three vacuum jets blow debris into bag, one thrust jet bows water out of the nozzle on back of unit, one drive jet that operates the drive gears and one operates the sweep tail.
It is best to disassemble down to the "water management system" listed above and rinse well, shaking it in all directions. Any small debris can clog the jets, including ants!
Feb 24, 2013 | Polaris 380 In Ground Pool Cleaner
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
My polaris is standing on end sometimes and will not change direction on its own
Make sure that the pool cleaners filter bag is not full of debris. It is likely that you have water in your float head. Remove the head float and shake it. If you hear water in it, you will need to order a new one. order a new one. Make sure that your hose floats are spaced evenly. Your thrust jets are probably not correct, which could make the directions not function properly. Try adjusting the jet and making sure that the sweep hose is sweeping properly.
May 05, 2011 | Polaris 380 In Ground Pool Cleaner
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
Older Polaris doesn't sweep
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380: Polaris Booster Pump Logo
46 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
