Question about Garden
Huskee 16 hp Tecumseh starts and runs great but
Huskee 16hp Tecumseh starts and runs great but after four long rows of mowing it shuts down. I wait three minutes then it starts back up and four rows later it shuts down
  • 755 Answers
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Posted on Jul 16, 2010
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc.
I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
Jan 14, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
Need a repair manual for a huskee 21hp. 46" cut model#13at688h731 George`s e-mail hvg.prop@cox.net
My MTD Huskee 21 HP 46" Lawn Tractor keeps breaking the transmission belt. We have replaced it several times and it breaks again after 4 or 5 mowings.
Apr 19, 2010 | Mtd Garden
My lawnmower engine cuts out
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 12, 2009 | Garden
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
