Question about Fujitsu Heating & Cooling
Outside unit freezing when ambient temp drops to 0 & below which causes the reverse cycle heating unit to stop working
  • robandfloyd Jul 16, 2010
    daikin reverse cycle air conditioner freezing on outside condensor and shutting down unit
    this occours when ambient temp reaches 0 and below
  • 4,070 Answers
When there is enough moisture in the air and the heater is running the moisture will freeze on the outside coils. When the unit senses this it reverses to the cooling mode which sends warm freon to the outside to melt the ice and then it will switch back to the heat mode. If this is the way yours is operating it is normal. It will help to shield it from rain and snow.
Posted on Jul 16, 2010
    Guru:
  • 468 Answers
Actually, as the ambient increases the outside unit becomes more inefficient. Remember, air conditioners are merely heat pumps, they pump heat from inside to the outside adding in their own heat generation while they do so. The hotter the outside temps are the less efficiently can the fans cool the condensor coil. If the condensor isn't as cool as it can be, the indoor unit will be able to evaporate to a smaller extent, effectively dropping your cooling capacity. Reverse cycle is by far the most energy efficient system. If you calculate electricity input to heat production, you get 300% apparent efficiency. The reason is that they are heat pumps - they move heat from one place to another, rather than generate heat by burning fuel. But as the outside temps fall the unit can start to ice over which them forces the unit to shut down. If you live in an area where the outside temps drop below freezing or get down to 3-5� then a reverse cycle might not be the best. www.fujitsugeneral.com/PDF_06/halcyon06_brochure.pdf
Rear window washers work in all temperatures. Front washers work only when outside temps are above 0 ! Once temps are below zero there is nothing!!!
Sounds like you got it. Water is freezing up the wiper motor or wiper transmission at a certain temp due to water leakage in what is supposed to be a sealed area. (inside wiper motor, wiper trans linkage). "SOUNDS LIKE" water may have seeped in the moer seal & froze it or stripped the gears of the wipers? Good Luck Frank M
Feb 15, 2016 | 2014 Hyundai Santa Fe
Heater will not activate until outside temp. is above 40 degrees
If you have a heat pump the compressor is locked out below that temp. If you have a dual fuel - hp/gas, the gas burners should come on as would the electric heaters if you have electric heat as backup.
Jan 19, 2016 | Heating & Cooling
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
HEAT PUMP OPERATION FOR TEMPSTAR SMART COMFORT 2400, MODEL THC436AKC1. LOWEST OUTSIDE TEMPERATURE FOR OPERATION?
I have installed many heat pumps and if it is installed without and ouside temperature sensor I would not recommend running it below freezing 32 degrees farenheheit. Running a heat pump at low outside ambient temps. can hurt your compressor and that is the most expensive part of the outside unit.
Dec 20, 2009 | Heating & Cooling
Should the LG LS-K-1830CL outdoor unit ice over on the coils when operating in the heat pump mode? Would this cause the unit to not properly heat the room?
Running the heat pump in low outside ambient temps. will definitely cause the coil to ice up. An ouside temperature senor or a wind baffle should be installed in climates that get below freezing. This would definitely cause the heat pump to operate at lowered efficency and maybe not at all. It should go into defrost mode if the sensor is working correctly when the coil ices up.
Dec 20, 2009 | LG LS-K1830CL Cool Mini Split Air...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Condenser frost's up on my heat pump
On a heat pump the system reverses during the heat cycle to bring in outside heat that will cause the outside coils to ice up. There is a defrost timer or pc board to send the unit into defrost every so often. This is a common problem with heat pumps or possibly low or refrigerant. Heat pumps will freeze up at low outside temps, but unless your in the Artic right now that shouldn't be a problem.
Sep 27, 2008 | Heating & Cooling
Short cycling
The most common cause is the fan relay on the main circuit board. However, if the outside temperature is 30degF and the inside is 60-65degF then the cause could be the insulation is ruined or missing on the backside of the unit's firewall. This can cause the unit's internal thermocouple wire to read below 45degF which is the freeze sentinal temp level. Anything below this temp level will cause the unit to come on for a few minutes to warm up the air and bring it to 46degF or higher to protect internal plumbing from freezing.
The best way to check for this is to manually set the unit to one of the heat modes and the thermostat up just until the heater comes on. Let it run until the unit turns itself off. Then set the mode switch back to Off and see if the unit still cycles on and off as before.
If it does then the main circuit board should be replaced unless you are comfortable de-soldering and re-soldering another fan relay in place.
Dec 20, 2007 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
77 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
