Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
Grundfos mq3-45 pressure booster pump keeps stopping and starting when using water..pressure tank shows pressure varying from 40 and drops to 20 then kicks in again...where is the pressure regulator on the pump
  • Anonymous Mar 27, 2014
    my static pressure without pump running is 40 psi...pump kicks on and pressure goes up over 100...can I adjust that?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
PUMP JUST RUNS AND WONT SHUT OFF MQ3-45
DOES THIS SYSTEM FEED YOUR HOME.DOES IT HAVE PSI TANK. WHAT COULD BE HAPPENING.IS.THERE IS A PRESSURE SWITCH (fyg-2) THAT WAS INSTALLED ON YOUR SYSTEM. THIS ITEM, DEPENDING ON IT'S MANUFACTURE.COME PRESET AT 20/40 PSI OR 30/50 PSI OR 40/60 PSI. THAT MEANS ON START/OFF START PSI. SO IF YOUR PUMP CONTINUES TO PUMP AND WON'T TURN OFF.YOUR SYSTEM PUMPS MAY HAVE SOME WEAR TO IT OR A POSSIBLE HOLE IN THE DROP PIPE THAT IS NOT ALLOWING YOUR SYSTEM TO REACH PSI THAT IT SET FOR. ALL U HAVE TO DO IS READJUST THE PRESSURE SWITCH TO THE PSI READING THAT IS ON PSI GAUGE.
Oct 28, 2011 | Grundfos MQ3-45 1 HP Pressure Booster...
I have a Grundfos MQ booster pump and it starts and stops while the water is in use instead of continuing to run until after the water is turned off. The manual says that it could have air the lines or...
Get a good tire pressure gauge insert it into the bottom of the tank, you should read about
12psi-20psi., depending on your system. If you get no reading or unstable reading, morethan likely you need to add air. Try to add air, if it wont accept it find a place to bleed water out
of the system. Is this a water heater or a boiler?
Sep 03, 2011 | Grundfos Plumbing
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos pump leaking?
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
Aug 01, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Hi there, what should the tank pressure be , please? The custemor says that the pump keeps on hunting(stop/starts all the time)
set at what ever the cut out on the pressure regulator is set at- if set to cut off[out]at 50 will pressurize tank to 50 and stop pump- will come on when flow brings pressure down and what ever pressure on is set at --if short cycling -bad regulator -set wrong- air bladder bad in tank-motor overheating -binding [[[
Jun 11, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
My pump, used to pressurise the water in the house, keeps coming on every 2 mins approx even though there is no water being used in my system. I have checked for leaks and am suspicous that the pressure...
If you have valves at the pre tank you can run it till it shuts down then close the inlet valve and the outlet valve. Wait and see if it goes on again. If so you have a problem in the pressure tank or the switch mech. If not open the outlet valve and wait. If it starts you have a leak somewhere in the house. If not open the intake valve and see what happens. If it kicks on then you have a problem with you check od backflow valve. If this is a shallow well pump it could be in the supply line also. Good luck.
Jan 31, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
490 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Jay Finke
Jay Finke
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
