Question about Kenmore 62802 Electric Dryer
Hi, I have a Kenmore Elite electric dryer model#
Hi, I have a Kenmore Elite electric dryer model# 110.64942300 which is about 5 years old. 5 months ago, no heat, so I replaced the high limit thermostat. Now 5 months later, the thermal fuse is blown. Could my heating element be causing these issues? How many ohms should my element be operating at??? If it meters out too high, then I'll replace it too. Please advise. Thanks, Ross
    Novelist:
    Champion:
  • 221 Answers
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Posted on Jul 16, 2010
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Posted on Apr 28, 2010
  • 9 Answers
SOURCE: model 110 73932101 kenmore elite.
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Posted on Apr 15, 2011
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
Brown marks on clothes from kenmore elite dryer
i used to be sears repairman ask him if there is a recall on your pacfic model .. betcha there is on the dryer drum tell him u want the whole drum replaced on dryer u know exsisting problem having on this pacfic dryer remember satisfaction gaurented or money back...
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Electric Dryer
Hi! kjsnell
Can you look up the first three digits of the model number and let me if you have any other comments.
Aug 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 62802 Electric Dryer Logo
281 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
