Question about Kenmore 16712 Dishwasher
Kenmore 16712 dishwasher is leaking. Not all the time, but 2 of the last 3 times. Any ideas what it could be?
  • Kenmore Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasherkenmore 16712 dishwasher is leaking - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Jul 19, 2010
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 09, 2015 | Kenmore Dishwashers
Black tar balls in Kenmore model #665.13722K600
No, don't run Coca-Cola in it! I would call a repairman immediately - you may have a rubber hose that is disintegrating, and you dishwasher could start leaking seriously!
Sep 05, 2012 | Kenmore Dishwashers
Kenmore dishwasher model 587.15102800 reset sequence
you can try the last 2 buttons on the right before the vertical LEDs. do a key dance one then the other 4 times. if all of your lights do not come on after that, your out of luck..... sorry
Jan 02, 2012 | Kenmore Metro Dishwashers
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Dishwasher leaking on floor
Leaking Dishwasher
heatman101
wata
Feb 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Leaks under left hand side of door; I've installed 2 new gaskets in last 2 weeks & new float switch; doesn't leak underneath
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Jan 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore Quiet Guard Dishwasher only starts when pressing start repeatidly
No personal experience with this machine, but two things come immediately to mind:
1. If the door latch is not quite closed then the machine still thinks it is open and thus will not start. Try gently pushing on the door as you push the start button. If no joy, then check to make sure that the latch mechanism (what can be seen of it - usually very little!) has no food deposits on it.
2. The start button contacts may be corroded. Try pushing the start button more firmly - and wiggle it at the same time.
Jul 16, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Leaking from the door
This has happened to us a few times. There is a gasket inside the door for a solenoid that operates the flap that opens to let dishwasher detergent out. The gasket went bad and water leaked through.
The only thing to do is replace the gasket. It's a $8 part. (A lot for a 1 inch square gasket!) They seem to last about 2-3 years.
Nov 09, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Kenmore 16712 Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
