Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My jd jx75 shakes excessively w/o the blade engaged.
When I start the mower it starts shaking excessively. The blade is not engaged at this time either.
  • Ned  White
    Ned White Jul 16, 2010
    The blade shouldn't have anything to do with the engine, it is independent, most small engine movers have to have the blade for the flywheel, it will not run without it. Did you try the spark plug? Just going to throw that out there.
    Sergeant:
  • 200 Answers
Make sure the motor is mounted tight to the frame.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Why has the mower started running erratically, blades not engaged, shaking and noisier?
getting ready to throw a rod through the side of block
Jul 11, 2015 | Garden
Craftsman mower deck belt tensioner keeps bouncing and shaking the deck
Bad pulley ???? Bent blade shaft,Bad bearing???
May 31, 2014 | Mtd Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
I have a JD 160 mower that shuts off when you turn on the pto switch for the blades, I have checked the charge in the battery and it is good, it will start to turn the blade and then the engine dies, just...
Most likely cause is the seat safety switch is not functioning properly, ie. when sitting in it to allow blades to engage, if failed it will act like there is no one on the mower and the blades get engaged it will kill the engine, like having the ignition shut off.
I hope this is helpful to you.
Aug 10, 2011 | John Deere Garden
I have a 1500 series Cub Cadet, 54 inch cut. I ran over a rope that wrapped around the blades shutting down the mower. I turned the mower off and removed the rope. I engage the PTO. I hear it click but...
put the rope back around the blades then go in reverse slowly, park the tractor where you found it prior to running the rope over, get off, shake your head a few times, then try it again, this time pick the rope up first! that should fix ya!
Aug 19, 2010 | Garden
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
330 people viewed this question
Top John Deere Garden Experts
Wayne Fellows
Wayne Fellows
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a John Deere Garden Expert? Answer questions, earn points and help others
