Question about GE DWSR483EBWW Electric Dryer
My dryer is making a funny noise, like there is friction on the drum and the back is unusually hot.
    Champion:
    Scholar:
  • 210 Answers
GE has some gliders the drum turns on they are teflon and wear out. When they do it will start rubbing and making noise. The drum don't turn as easy as it should. G E is very bad about this sometimes it will wear into the plastic that holds the durm up and the whole thing has to be replaced. I wouldn't buy a G E old ones are ok.
Posted on Jul 16, 2010
  • Virgil Watts Jul 16, 2010
    Forgot to tell you to check the blower wheel and the vents for lint and other things stoing it up. That will make it run hot and not do a good job of drying. Also could blow the thermal fuse or cause a fire.
    Always clean the lint filter after each use.
Why is my divinci 6030 receiver making loud rumble noise when I push the power on in the back of unit. I have nothing hooked up to it.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Dec 17, 2014 | Dryers
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Asko dryer make a banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 02, 2014 | Asko Dryers
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
How to fix Frigidaire GLER341A hums and vibrates when hot?
The blower:
The bearings:
May 05, 2014 | Frigidaire GLER341A Electric Dryer
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
My dryer just started making a funny noise. It
un plug dryer and take it apart and see if belt come off or broke
Jun 18, 2009 | Kenmore 66942 Dryer
Drum Noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hjdj
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Drum in dryer not turning but still heat
had the same problem.Found sox stuck in the blower.Try to check that it worked for me.
Apr 02, 2008 | Dryers
GE DWSR483EBWW Electric Dryer Logo
231 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
