Question about One For All URC-3021 Remote Control
What are the set up directions - One For All URC-3021 Remote Control
I had my direct tv disconnected and now I can not get the tv to respond to the reg. visio remate
Hi, In the direct tv settings you have to set it back to the vizio, direct TV builds in this remote programming feature, of course the TV needs to be on showing the direct TV menu first,
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 13, 2014 | Vizio L32 32 in. LCD HDTV
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Big sreen tv problem
Are you talking about the direct remote or the remote for the set?
The direct remote should be programable for most sets and most set remotes will program for direct boxes.
Mar 16, 2012 | Televison & Video
How to have internet connection on a PSP
Hi there. Here's how:
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly.
23. Launch Wipeout Pure and go to the Download option in the main menu.
24. Select the name of the new connection you just made (ex. WebConnect), connect, and enjoy browsing the internet on your PSP.
Hope this helps.
Thank you for using Fixya!
Jun 30, 2011 | Sony PlayStation Portable (PSP) Console
Where is the aoss botton on the psp3000
Hello here's a quick guide for aoss!
2. Go to Settings.
Good luck and please rate! Have fun gaming!
Jun 17, 2011 | Sony PlayStation Portable (PSP) Console
Factory suspension settings
Spring preload FR
To increase the spring preload and
thereby harden the suspension, turn
the adjusting bolt on each fork leg in direction
a. To decrease the spring preload
and thereby soften the
suspension, turn the adjusting bolt on
each fork leg in direction b
NOTE: _
Align the appropriate groove on the adjusting
mechanism with the top of the
front fork cap bolt.
_
CI-10E
Rebound damping force
To increase the rebound damping
force and thereby harden the rebound
damping, turn the adjusting screw on
each fork leg in direction a. To decrease
the rebound damping force and
thereby soften the rebound damping,
turn the adjusting screw on each fork
leg in direction b.
CI-02E
Compression damping force
To increase the compression damping
force and thereby harden the compression
on each fork leg in direction a. To decrease
the compression damping force
and thereby soften the compression
each fork leg in direction b.
CI-02E
1. Current setting
2. Front fork cap bolt
Setting
Minimum (soft) 8
Standard 6
Maximum (hard) 1
1. Rebound damping force adjusting screw
Minimum (soft) 26 clicks in direction b*
Standard 13 clicks in direction b*
Maximum (hard) 1 click in direction b*
* With the adjusting screw fully turned in direction a
1. Compression damping force adjusting screw
Minimum (soft) 20 clicks in direction b*
_
Although the total number of clicks of a
damping force adjusting mechanism
may not exactly match the above specifications
due to small differences in
production, the actual number of clicks
always represents the entire adjusting
range. To obtain a precise adjustment,
it would be advisable to check the number
of clicks of each damping force adjusting
mechanism and to modify the
specifications as necessary
CI-10E
Rebound damping force RR
damping, turn the adjusting screw in direction
a. To decrease the rebound
damping force and thereby soften the
rebound damping, turn the adjusting
screw in direction b.
CI-14E
in direction a. To decrease the compression
soften the compression damping, turn
the adjusting screw in direction b.
CI-14E
Setting
Minimum (soft) 1
Standard 4
Maximum (hard) 9
Whole process where need to turn toward "a" means clockwise and "b" counterclockwise. From Yamaha service manual. Hope this is good enough info to help you out. Good?
May 03, 2010 | 2002 Yamaha YZF-R1
How to get on internet with pspgo?
Go to Settings.
HOPE THIS WORKDS =P"Im a kid but Ill solve your question!"
Oct 05, 2009 | Sony PlayStation Portable (PSP) Console
Hard reset
Hi Friend,
You can't hard-reset it on your own, that can only be done by a Nokia Care Center by flashing the firmware again on the phone.
The phone itself only offers a "soft" reset which only resets the settings.
if you mean a master reset (back to factory settings)
From the stand by screen, select Menu by pressing directly in on the navigation pad.
Scroll to Settings, and select by pressing directly in on the navigation pad.
Scroll to Restore Factory Settings, and select by pressing directly in on the navigation pad.
Enter current Security code and select OK by pressing directly in on the navigation pad.
NOTE: Default Security Code is 12345.
Regards,
Ayyasam
Jun 04, 2009 | Nokia 6085 Cellular Phone
Directions to set watch
She clearly states that she lost her instructions to SET THE TIME.
Why didn't you ask her where you could send it.
Nov 22, 2008 | Timex Expedition 84601 Wristwatch
How to set up psp to internet
hey...there, try this one and follow the instuction.
2. Go to Settings.
Feb 13, 2008 | Sony PlayStation Portable (PSP) Console
One For All URC-3021 Remote Control Logo
299 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
