Defy automaid front loader.drum not filling up with water it by-passes straight out the drainage pipe.
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
SOURCE: defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Posted on May 11, 2009
  • 17 Answers
SOURCE: How do remove the bearing behind the drum on Defy
Try Youtube below. This video really helped me when I replaced mine. Basically the entire machine has to come apart. If you are lucky, its just the bearings and seal. I replaced my bearings and seal for under $30. The bearings are likely Chinese in origin, mine were on my Kenmore, I replaced with more Chinese, you can buy SKF which are more money but likely wont last any longer, basically submerged in water a lot. The bearings will be able to be knocked out of the plastic drum with a little effort once you completely dismantle the plastic drum which has about 20 bolts or so. Now remember, the bearings only seat in one way, so dont beat on the bearings too much with a hammer and screw driver, they should come out without too much effort. They press in place, so save the old bearing and lay it on top of the new one to tap it in place. It depends on which model you have. It is likely a Frigidaire, look at the drum when it is exposed, it may be stamped. Anyway, it does not matter, if it is the bearings, they will need changing, and the rubber seal that goes over the shaft too. The seal may not look too worn, but it is, and the water has come in to where the bearings sit, so you can guess at what happens after awhile. Also, if you are not so lucky, the aluminun tribar housing holding the stainless drum onto the shaft will be cracked, if that is the case, you may want to look at another machine as parts may be too expensive. Just remember, the bearings will be standard type, and will be stamped into the race for identification. Google the bearings numbers and you will find them. Find a local supplier of bearings and they will find them for you, and the seal. It takes about 3 hours to dismantle, going slow, and a little less back together If you are a handy person, you can do it but on a scale of 1 to 10 it is about a 8 for difficulty. The hardest part for me was getting the darn aluminum belt pulley off the back of the drum shaft, what a nightmare, it was siezed, I had to use my propane torch being careful not to overheat the plastic drum.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=related
Posted on Sep 20, 2009
Testimonial: "Thanks, looks as though it wont be the train smash I originally thought it mite be"
SOURCE: My Defy Automaid 600 does not dain the water out,
My defy automaid 600 does not drain the water. The pipes is not blocked.
Posted on Mar 26, 2011
  • 6277 Answers
SOURCE: After a complete cycle the
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 06, 2011
My defy automaid 600 front load washing machines barrel seems to be loose and is knocking against something. How to I inspect it to see what is wrong.
Hi, it could be a few things either drum bearings are needing renewed or drum tension / shocker is not functioning properly.
Jan 25, 2016 | Washing Machines
Why does my washing machine leak water from the detergent tray?
Check the water pressure of your house. If it is above about 75 psi, it will cause the problem you describe.
If you house pressure is fine, then either your water inlet valve on the wash machine is opening up too much during fill, or the dispenser itself is defective.
If your wash machine is still under warranty and your house pressure is fine, then have a repairman take a look at it.
Oct 19, 2014 | Washing Machines
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
Pre
Sep 05, 2014 | Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
My Defy Automaid 600 does not run water in. Tap is open. Pipe is not blocked. All the other funtions work.
HI. this is a failed inlet water valve assembly. you will need to replace this assembly asap if possible.
Jun 11, 2009 | Washing Machines
Defy automaid won't spin
Good luck.
Mar 10, 2009 | Washing Machines
Help
i dont know if this is right but your washer might be old or it might need a flu pipe. the other reason is that one of the other pipes like the drainage pipe is blocked or old or rusty and cant let water past it, since your drainage pipe is different from the washing pipe the water stays their and you need to turn the spin cycle on to let it pass through the washing pipe instead of the drainage pipe.
Dec 27, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
