Question about D-Link Wireless
I just purchased the D-Link wireless router. Connected everything ran the CD and I'm not connected for some reason? I may have connected something wrong, but I was following all the instructions...my error message is that one of my devices does not appear to be on the network map? What ever that means?
  • tryune Jul 16, 2010
    what operating system are you using? (Windows XP, 2000, Vista, 7, Mac OS) If windows Vista- you want top make sure your network device is working and not disabled, go to start>control panel>network and sharing center>network connections(its link on the left side that says manage network connections) you should see a local area connection that's your wired network card and a wireless network connection. My advise is to connect via wire first to make sure the router is functional then configure wireless. Unfortunately there's alot of variables in your problem (router, computer and modem (DSL or Cable)) and I'll need to walk you step by step in configuring it to make sure you're up and running. send me more info such as 1. are you connected directly to the router like on port 1 and if so does the #1 light flash on the router 2. can you enter the router config screen? or do you know how? 3. if you can enter the setup can you see a valid ip address from your ISP as you can see its simple but time consuming, easier to talk you through it than back and forth typing but I can help you.
    Guru:
  • 825 Answers
First of all for using a router you need not install any cd...
try connecting your laptop to any one of the wired (lan) ports of router using an ethernet cable and check whether you are able to access or not...
if you are able to access then search for the wireless networks in range...
you will see linksys network... try connecting to it and access wireless internet...
if you are not able to access internet even through ethernet cable then you need to configure your router first...
to get an idea of how to configure your router have a look at this link...
Posted on Jul 16, 2010
I installed my D-Link DI-784 six days ago. It's connected to a Dell 8100 running Windows 7. It worked fine until an hour ago, when it stopped broadcasting. The router is connected to a DSL modem. If...
It is possible that a neighbor purchased a wireless access point that it on the same channel and they are competing. Change your wireless channel. You could also try a hard reset. Instructions at D-Link's website. Good luck!
Apr 08, 2011 | D-Link (DI-784) Wireless Router
Have wireless through Verizon, everything is connected correctly and verizon has ran their tests and everything is good, they are telling me it is within my computer something with wireless network adapter
goto start select my computer then from the side menu choose my network places then view network connections. check to see if its allowing you to connect to the router if not double click the connection choose the support tab and select repair. this should repair the connection
Jan 31, 2011 | HP Computers & Internet
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Where can i purchase another wireless-n broadband router setup cd-rom
you can setup the router by accessing it config site.
http://192.168.1.1
username: admin
password: (blank)
make sure that you are connected using your ethernet adapter
Jun 27, 2010 | Linksys Wireless-N WRT150N Router
I have a linksys wireless router and I connected to router but when I try to go to a web site I get the error not connected to the internet
That only means your router is not properly setup.
If you still have the cd that came with the product , just ran the cd and follow the instructions.If you dont have a Cd , you can setup the router manually by logging into the router web interface.
The address of the router is http://192.168.1.1 No username and password is admin. ( this is the default)
Once you get inside the router page, just setup the unit based from your ISP settings.
If you want a walk thru on this step, it would be good to call linksys techsupport at 1800linksys.
Cheers,
KJ
May 20, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless Connection Problem - D-Link 1310 Router
This is a firmware problem of your router to correct this one better do a firmware upgrade on your router and everything should be working after that...
Sep 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I just purchased a D-Link 2.4GHz Wireless Broadband Router
U need to confirm that your router is connected to cable/DSL modem that has access to internet from ISP.
This is due to DI524 just a wireless router, u need to add in a modem for internet access.
Mar 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
