Question about Panasonic PV-GS300 Mini DV Digital Camcorder
Panasonic PV-GS300 I have a panasonic digital mini-dv camcorder that cost about 400. It is not even a year old. I dropped it but it works except for the the LCD screen which has a crack and is only showing a white light. Instead of sending to a repair shop (which will cost me about 200.) is not better for me to try to replace the lcd screen myself? The part does not cost more then 70. How hard is it to merely take off the old broken lcd screen and replace withanother. Is it plug and play or does it require more complicated electronic work? I also dropped my pv-gs300 and cracked the LCD screen.  Can anyone please tell me how much it is for a replacement screen and were can I purchase one?  How dificult is it to replace? Thanks
  • zip9211 Apr 25, 2008
    Thank you all so much I ordered the screen and I was pretty surprised how easy it was to replace (I am not gifted when it comes to any type of electonics). Long story short with all your help I was able to order and fix it myself. One more thing..how do "rate" the advise you all gave me?
  • 3,037 Answers
It is only one item that you are talking about above right?
Anyway to replace the screen (All brands are similar, the one I am most familiar with is Kodak which is what I am basing these directions off of), remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera to help prevent future screen cracking from accidental dropping.
Please Let me know if you have any further questions.
Thank you for using Fixya and Good Luck!
Posted on Apr 21, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • Benjamin Patri
    you can order one through the manufacturer or through an electronics store
  • Benjamin Patri
    Benjamin Patri Apr 26, 2008
    no problem, glad you were able to fix it
    Genius:
  • 3,422 Answers
HI,
The best solution is that if it is under warranty then immediately return it.Atleast they will charge you less.If you want to replace the screen by yourself then go ahead but in case if you spoil anything else then this will avoid you r warranty and you will be charged more.
I'll let you know from where you can get the replacement part.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 21, 2008
    Nope i don't think there are any parts available for this model online.
    I believe you will have to get it serviced.This is the best and the only solution.
    Goodluck once again..
    Genius:
  • 1,226 Answers
You can do repair by it yourself, you should be carefull with all the parts which is very sensitive, You will need a special tools or correct tools to remove the lcd.
All part are only fitted, electronics wire is also fitted in it, only the matter is to replace only the identical lcd.
may this help, melnavz
I will search the procedure on how to disassemble i will notify you soon.
Panasonic PV-GS300 Mini DV Digital Camcorder Driver For Windows 7 I have used this camcorder on Windows XP
Okay, it is a pain in the neck, but it will allow you to get your videos off of the GS300 and into a usable .avi format...
If you go to the Panasonic Website, it will give you an option to download two video editing programs. Movie Studio and SweetMovieLife. Download SWEETMOVIELIFE, the other program is very limiting, but SweeMovieLife will capture the video and save it as an .avi file and you can then movie it into a better editing program such as Camtasia or Microsoft Movie Maker. It adds a few extra steps to the process, but will at least allow you to use the GS300 in the Windows 7 Environment until Microsoft wakes up and comes up with a fix for this extremely annoying issue!!! Hope this helps! :)
P.S. If you try to use MovieStudio, it saves the file as an .hap file and does not give you another option. None of my "real" video editing programs recognize that extension. Personally, I think the program was pretty useless.
Jan 19, 2010 | Panasonic PV-GS300 Mini DV Digital...
Dropped mini dv tape into water
Do you mean tape only?If no salty sea water you can use it...if salt no resalt...;)
Oct 25, 2009 | Panasonic PV-GS300 Mini DV Digital...
"wrong format" error panasonic pv gs9
You really need a panasonic camcorder or need a new camcorder that can read your mini dv tape. good luck
May 04, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Panasonic camcorder skips on playback
Try to clean the head by using Head cleaning casatte,if the problem remains same .The head is week .For more information u can call 9448259620
Feb 16, 2008 | Panasonic PV-GS300 Mini DV Digital...
Panasonic PV-GS300
DO NOT TOUCH IT! i took apart a vx1000 and broke more than i fixed. i wouldnt send it in either. just buy another camera. or **** and try to fix it. ITS hard work and onky if ur patient, should u persue the task!
Sep 10, 2007 | Panasonic PV-GS300 Mini DV Digital...
Open Questions:
Panasonic PV-GS300 Mini DV Digital Camcorder Logo
271 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
